Page 24 of 37 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 370
Thread: Polo Problems & Fix Register
  1. #231
    Kellyville
    Quote Originally Posted by leasaunce View Post
    contact VW, but just before you do that, speak to the regional manager of VW. He usually comes in to the dealer once a month. Then if Regional manager tells you he it's a normal condition, then email or call VW australia and make a formal complain. on the other side, if you still have 1-3yrs of warranty, just keep on replacing it. but then again it's gonna be a hassle for you and the dealer (hopefully by then they'll say "yes its the car's fault")
    Yeh i'll see how it goes replacing it this fourth time, maybe fourth time lucky. If not i'll try that. Ive still got about 1.5 years warranty left but what happens when that runs out?!
    Thanks for the advice leasaunce. Have you had the same issue??
  2. #232
    Jun 2008
    Exclamation
    Quote Originally Posted by Kev_GTI View Post
    no i have a different issue with VW, I ain't happy with the way they dealt with me. But lets not rant here, so pretty much that's what I did. If they haven't fixed the problem by the time your warranty runs out, just let VW know about it and i'm damn sure they'll compensate you. If no i'll be PPPPPPPPPPPP!!!!!
  3. #233
    Kellyville
    yeh ive had some funny experiences with dealer service too, Hope you sort yours out
    Thanks!
  4. #234
    Apr 2009
    Please Enter Location
    hi everyone
    i have a leaky wheel that leaks reasonably little when i keep the pressure at ard 250kPa. But the situation got worse after i pumped it up to above 300 for handling. I checked the tire, no nails or something like that, could it be a deformed rim?My polo is running on the original steel wheels
  5. #235
    Nov 2006
    Quote Originally Posted by Jonathan View Post
    hi everyone
    Swap with the spare, take it to a tyre center and they'll have a big tub of water to submerge and look for any small leaks. This will show if it's leaking from the rim or from a small puncture. Had this happen once, the tyre pressure monitor works a treat.
    aus liebe zum automobil
  6. #236
    May 2009
    PROBLEM: 1st to 2nd Gear Crunch
    DESCRIPTION: occasionally crunchs on 1dt to 2nd gear changes, esp if you try and change gear quickly.
    FIX: Booked into Lennock VW (ACT) one month from now (is it normal to have to wait a month?)
    PROBLEM: Coolant loss.
    DESCRIPTION: After long journey (Canberra - Sydney) on restarting next day coolant is below minimum and requires top up. Doesnt do this on a day to day basis but has happened twice on long drives now.
    FIX: as above, will update when looked at.
    06 > 9N Polo GTi
  7. #237
    Mar 2007
    Yep. Exactly the same problem. Had them replaced twice at Denlo. I have front and rear swaybars and front strut brace as my only suspension mods. Since I'm currently off the road, I have not bothered to get them fixed again, looking for an aftermarket solution, not sure if getting coilovers would help?
    Hey has any one had an ongoing problem with their rear shock mounts needing to be replaced on there polo gti?
    '07 CW Polo GTI
    'Roof::Leather::Tint
    GIAC::Whiteline RSB + FSB::Forge SB:ogbone
    Glossy B::Cubby::Honeycomb::Antenna
  8. #238
    Aug 2008
    Quote Originally Posted by Bluey9N View Post
    Gearbox recall. Search the forum, there's plenty of threads relating to this.
    I have had the recall done and it rectified the issue for a short time but now it has returned.
    If it has been doing it for a while it may have damaged the gearbox which means a replacement one is in order
    Cheers,
    John
  9. #239
    May 2009
    Quote Originally Posted by JCM308 View Post
    Its going in 2 weeks from now, I called about this 2 weeks ago and 21st is the soonest they can fit it in and im worried my warranty will have run out around then.... If i reported the issue prior to manufacturer warranty running out but they couldnt look at it till after its expired will it still be covered?
    It apparently has 2 years dealer warranty on it but i dont know what that covers?
    06 > 9N Polo GTi
  10. #240
    Canberra
    I have had a terrible rattle which was coming from what I thought was near where the dash meets the doors on both sides of the car. Anyway, I could never find it until couple of days ago my drivers side headlight bulb blew. When I was changing the bulb over, I noticed a screw was loose on the headlight assembly. I checked the passenger side and it was loose as well. I tightened them and the rattle has completely gone away. I now have zero rattles.
    I guess you should never discount that the rattle could be coming from somewhere unexpected. I know someone else here was told by a dealer that it was radiator mounts that fixed the rattle. Check you torx screws under the bonnet near the front.
