Page 15 of 37 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 370
Thread: Polo Problems & Fix Register
  1. #141
    Apr 2008
    No, its under warranty.
  2. #142
    Nov 2006
    Quote Originally Posted by Piotr View Post
    Yeah I know, just the way I read it made me think they made you pay for it.
    aus liebe zum automobil
  3. #143
    Nov 2006
    Unhappy
    Make - Polo Tdi
    Kms - 19500
    Mods - None
    Car Usage - Daily use
    Problem - Engine
    Description - Was driving along, shifted to 5th gear applied throttle and was greeted by a loud scraping sort of noise for about 5sec, followed by copious amounts of smoke from exhaust. Upon parking the vehicle 100m down the road, oil spotted dripping from exhaust.
    Fix - Got it towed back to the dealer, it requires a whole new engine, apparently a fault with the turbo, allowed oil to pass back into the engine and it has suffered some sort of failure (I have not been told much about it apart from the fact that it is a fault that is being covered under warranty) 4-5 weeks wait for a new engine
    1995 Golf VR6 Colour Concept | Eibach Pro Kit Springs | K&N Pod in custom airbox | Suitcaseless exhasut
  4. #144
    Mar 2007
    Quote Originally Posted by wakdog View Post
    Make - Polo Tdi
    Kms - 19500
    Mods - None
    Problem - Engine
    Ouch! Bad luck, Mate.
    Dave
  5. #145
    Mar 2007
    Eastern Suburbs
    Polo GTI Gearbox
    Hello boys and girls,
    Problem: Crunching noise when changing from 1st to 2nd between 4-6000rpm.
    1st fix: apparently a recall by VW for putting the wrong gearbox fluid in vehicle. changed fluid.(This did not work)
    2nd fix: Full replacement of second gear after having to replicate the noise with one of the mechanics in the car.
    Will be interesting to see how this goes, i am still running it in, so will report back on it later. This was all done under warranty.
    My red pocket rocket
  6. #146
    Jun 2008
    Angry
    Hi all ... please help
    MAKE - Aug '06 POLO GTI
    KMS - 7800km
    MODS - None
    CAR USAGE - Daily, short drive to work
    Problem: Whilst driving along, power is removed momentarily to all electrical systems affecting the Radio, Power Steering, ESP, ABS etc. When the power comes back on, not all electrical systems necessarily work (eg No power steering or ESP switched off and cannot be turned back on. In both cases switching the ignition off and on again fixes the problem ... until the next time).
    The problem often seems to happen turning right, and the last time the problem was fixed, I believe they found some points to the power steering were loose.
    Just happened again and this will be the 6th time that I have returned the car for the same fault.
    I am in Adelaide, and getting the dealer to look at it ... there is only 1 VW dealer in Adelaide.
    Anyone else who has had similar issues ...
    Thanks
  7. #147
    Dec 2006
    Mods vs non mods
    hey guys just noticed one thing that seems to be common on this problems page. Guys with no mods seem to be having more problems then guys with mods
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  8. #148
    Maybe we're just lucky Jas - either that or we don't comment on them hehe!
  9. #149
    Dec 2006
    yeah good point jon will shut my mouth
  10. #150
    Feb 2008
    Make: Nov 2007 Polo GTI
    KM: 11,200
    Mods: Rear Sway Bar, Froge BOV, APR Torque Arm Bush, K&N Panel Filter
    Usage: Daily running to work, Cruising on the weekends.
    Problem: After buying the car in January 2008 in Penrith, I drove the car up to Darwin. For the length of the 4,000km trip myself and my father noticed the Air Conditioning system loosing its coolness(We thought this may have been because the outside ambient temperature being nearly 50 degrees had something to do with it).
    Upon arriving in Darwin, the A/C system had dumped all of its refrigerant(an absolute bastard in the Darwin Wet season!!)
    Fix: Took the car to the local dealership where they re gassed the system, and added a detection dye to the system too.
    Dumped the gas for a second time. Was told that there was a hole in the condenser from a bird strike, even though there was no leak detected there, and that I would have to pay $800+labour for a new condenser. A leak was however detected in the drivers foot well with a sniffer. I refused to pay for a new condenser, and told them to replace the T/X Valve, and Evaporator.
    4 months later with no A/C, and many unreturned phone calls, the parts arrive, and the problem has finally been fixed!! Yay, I have A/C again!!
