I’ve recently replaced my passenger window regulator and motor. The window will only work 10 minutes after the battery has just been plugged back in and only from the passenger window switch but not the driver side switch. After the 10 minutes there is no sign of the window working.
the abs and traction control light are up on the dash, the code says it’s the front right speed sensor but I’ve replaced all of them and it still shows up with the same fault code.
