Page 7 of 37 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 370
Thread: Polo Problems & Fix Register
  1. #61
    Mar 2007
    Melbourne, Vic
    Quote Originally Posted by Funkdancer View Post
    Not sure if anyone has missed a cancel cruise control button... Got one on my Euro. I'd been using the brake pedal to cancel cruise, but then I found that depressing the clutch pedal will do the same thing - looks a bit better to the guy behind too.
    You can cancel cruise with the cruise control on/off switch. When you push it not all the way it does a cancel while remembering the previous speed. Push it till it clicks into the other position and it turns off completely and forgets the speed.
  2. #62
    Feb 2007
    Anyone else ever needed to top their coolant up?
    I've found that - after nine months and approximately 6000km, I've hit "Low". No warning lights or anything, and no visible leaks in the system that I can see. I'm going to have to get a bottle of G12+ and a bottle of distilled water, and give it a bit of a top up.
  3. #63
    Canberra
    My levels haven't moved in 6000kms in 5 months.
  4. #64
    Alfred Cove, WA
    I had a low coolant light come on just before my 30k service. The guys at the dealership didn't seem too worried that the car was loosing coolant somewhere.
  5. #65
    May 2007
    Burleigh Heads, Qld
    Anyone know if the rear wiper fluid is from the same reservoir as the fronts? Can't find a rear reservoir so I'm guessing it's a yes.
  6. #66
    Canberra
    Quote Originally Posted by PeterHBne View Post
    I am pretty certain there's only one reservoir. Given it takes a while for the fluid to come out at the back, I'd say it's just the one.
    Also, I've never had a car with two reservoirs, I always thought all cars just use the one?
  7. #67
    May 2007
    Burleigh Heads, Qld
    My Daihatsu Charade had two - filled a reservoir above the tail light with the hatch up
  8. #68
    Canberra
    Well there you go. Learn something everyday.
  9. #69
    Mar 2007
    19 months and no lowering of the coolant level.
    Dave
  10. #70
    Mar 2006
    South Hobart Tasmania
    Quote Originally Posted by Ben_GTI View Post
    I had this too but happened every 5000k and took my car in the vw ro find a hair line crack in the radiater all fixed under warrenty.
