Page 23 of 37 FirstFirst ... 13212223242533 ... LastLast
Results 221 to 230 of 370
Thread: Polo Problems & Fix Register
  1. #221
    Mar 2009
    Quote Originally Posted by Bumpknuck View Post
    have you tried depressing the white ball/button on the holder itself and feeding it back in? happens to mine sometimes, the white ball thingo on the holder is a release of some sorts
    That white ball button is meant to release the adjustment "grip" of the cup holder, so you can pull it out toward you. Useful, as it saves you from pushing the cup holder all the way back in & out again to fit your cup in.
    MY16 MK7 Golf GTI
    - Manual - Sunroof - Folding Mirrors - Lock/Unlock Chirp - 4x Indicator Flash - Traffic - MK7.5 LED Tail Lights with Sweeping Indicators - Dynablink Sweeping mirror LEDs - White LED's on rear rego plate -
  2. #222
    Dec 2008
    Cup holder fixed under warranty today
    Backed into pillar at shopping centre later
    quoted so far at $480-$550 to fix (RHR Tail light/ rear mould/bumper fix/paint)
    Oh well bad things come in threes, and this was the 3rd so hopefully it'll be ok.
    If anyone can recommend a quality and reasonably priced mechanic (preferably not to far from the city <Brisbane>) please PM me.
  3. #223
    Mar 2009
    Sorry to hear that, imprompt.
    Hope she get's fixed quickly. At least it wasn't a drive-by, where the offender drove off....
    MY16 MK7 Golf GTI
  4. #224
    May 2009
    Please Enter Location
    Make: 2006 TDI Polo
    Kms: 35000
    Mods: None
    Car Usage: Personal (mostly just to and from work daily)
    Problem:
    1) Power Assist light has come on when turning into a parallel car spot or driveway, a few times the steering has also died but has been resolved after restarting the car. This has happen 6 times in a month (the time that I have owned the car), although the problem has been occurred more to begin with and less often as time has gone on.
    2) Noticed headlights did a slight flicker when slowing to pull into a car space a week ago and noted that the clock and trip meter had reset.
    Solution: Took back to dealer service centre who can't recreate the problem, therefore no solution has been found.
    Any advice would be appreciated
    Thanks
    Jo
  5. #225
    Mar 2007
    Melbourne, Vic
    Quote Originally Posted by JosieH View Post
    Make: 2006 TDI Polo
    Kms: 35000
    Mods: None
    Problem:
    Thanks
    Jo
    I had my power steering cut out a few times early on (including when i drove out of the dealer after delivery). Was diagnosed to be a faulty steering wheel angle sensor. Since that was replaced i haven't had a problem since. If you had your headlights dip and computer/clock reset when it happened once then it sounds like an electrical issue. The powersteering on the polo is electrically operated instead of being driven directly off the motor.
    Ben.
  6. #226
    Essendon
    Before I bring it up with my dealer, I wanted to ask here first.
    Is anyone else having issues with the carpet and/or cloth seats? I'm pretty meticulous when it comes to looking after my stuff, but I'm finding the carpet is showing excessive signs of wear in such a short time. Not only the carpet, but the seats have an appearance of high usage with "fluffy" patches.
    It's been one of my main concerns because at this rate, in two years time, my interior is going to look like crap.
    I should also point out that my car has 10,570km and the rear seats have hardly been sat in, but the fluffiness would suggest I'm carting kids around all day.
    Sunroof // ICT Tint // Seats // Steering wheel
  7. #227
    Jan 2009
    Quote Originally Posted by pixl View Post
    I haven't experienced this (carpet or seats) - cars not 18months yet and 17,000km.
  8. #228
    Jun 2007
    Perth
    Quote Originally Posted by DBM View Post
    Problem: Whilst driving along, power is removed momentarily to all electrical systems affecting the Radio, Power Steering, ESP, ABS etc. When the power comes back on, not all electrical systems necessarily work (eg No power steering or ESP switched off and cannot be turned back on. In both cases switching the ignition off and on again fixes the problem ... until the next time).
    Anyone having this problem end up getting the issue solved? Friend of mine has asked me to look into it, as they are having identical issues. The dealer has tried replacing battery, alternator etc. And their warranty has just expired, unfortunately, the problem has come back again.
    My Polo on the other hand:
    MODEL - POLO GTI
    KMS - 34K
    CAR USAGE - every day
    PROBLEM: Air-con
    DESCRIPTION: No cooling, happened in the middle of summer. Noticed fluid leaking from the left-hand side of the engine bay.
    FIX: Replaced condenser, under warranty.
    PROBLEM: Cup-holder
    DESCRIPTION: Jammed it in while cleaning the car.
    FIX: Service guys were good about it. Replaced under warranty
    PROBLEM: Speaker
    DESCRIPTION: Buzzing from the left-hand rear speaker
    FIX: Replaced under warranty.
  9. #229
    Kellyville
    Rear shock mount replaced 3 times and counting...
    Hey has any one had an ongoing problem with their rear shock mounts needing to be replaced on there polo gti?
    I initially had a rattle coming from the back of the car which was eventually diagnosed as coming from the right rear shock mount. This was replaced, twice at denlo parramatta and once at mcgrath liverpool, and the problem keeps happening. Bringing it back to mcgrath to have it shock mount replaced again. Always on the same side and seems to go only a few weeks after its replaced.
    The dealer mechanics dont really have any solution, they seem to think its a problem just with the shock mount (ie. the issue is not related to any other suspension component). Therefore, they just replace the same thing every time. I dont have any suspension mods - my car is pretty much stock. Was thinking of contacting VW australia. Any advice on what i should do?
  10. #230
    Jun 2008
    contact VW, but just before you do that, speak to the regional manager of VW. He usually comes in to the dealer once a month. Then if Regional manager tells you he it's a normal condition, then email or call VW australia and make a formal complain. on the other side, if you still have 1-3yrs of warranty, just keep on replacing it. but then again it's gonna be a hassle for you and the dealer (hopefully by then they'll say "yes its the car's fault")
