Results 1 to 10 of 821
Thread: Polo Picture Thread
    Mar 2010
    Lynbrook, Victoria
    Quote Originally Posted by ssman View Post
    No it was very easy 3 bolts for the air pump- one bolt for the support- disconnect the fuel lines-work the fuel rail slowly up keeping the injectors intact-remove 4 air lines-disconnect electrical connection-remove intake hose and remove bolts and 2 nuts from mani. Thats it
    Caution though there is a bit of dirt/junk above the mani and under the flange in these little pockets so when you take it off be prepared, I used a vac at the same time, go slow and it will be fine.
    Cheers ssman
    tough setup u have there. would be even better to actually see it in person, if thats possible seeing as your in S.E melbourne.
    May 2009
    S.E. Melb Vic
    Ya Im always up for anyone to stop by and talk shop.
    Essendon
    Should setup an 'ssman meet' -- Would be awesome to see what've done to it.
    Sunroof // ICT Tint // Seats // Steering wheel
    S.E Melbourne
    new polo on air ride.... **** wheels though
    some 9n on air to even out the ratio...much better wheels too.
    haha just got to the end of the thread for that 9n Polo
    BAM!!
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
    Jan 2009
    wow, all those rims are hideous. Each to there own, but seriously WTF...
    Point Cook, Vic
    whilst I wouldnt paint them red. I think some nice chunky rims actually work well on the Polos. Makes them look a lot less top heavy.
    FOLLOW US ON FACEBOOK
    S.E Melbourne
    all of them really? fair enough I think the borbets work, pretty classic set of rims, and in red they work well against the black, personally I'd have a lower offset and more dish though.
    Quote Originally Posted by Whubbsie View Post
    BAM!!
    man that's not even that low! As if you'd fork out for air ride when you can static drop it that low and daily it!
    tough looking set up though and KILLER stance
    Just cos I can
    Point Cook, Vic
    you wouldnt be able to go lower with those wheels/tyres. Not really driveable sitting on the rear tyre like that. Air ride would come in handy if you wanted to move it
    I think Dom has the right idea with airbags. Not quite so aggressive on the wheel offset so you can lay her all the way down.
