I WANT ONE! Just one ... is that too much to ask?
Dave
Dave
Polo 4 Super 1600 Gravel
Specifications
Engine Petrol engine, transversally installed, water-cooled
4 –cylinder in line, 16 valves
Bore : 76,5 mm
Stroke : 86,9 mm
Capacity : 1598 cc
Power : 232 hp at 8750 revs
Max Torque : 200 Nm at 6250 revs
Engine management : BOSCH 3.1
Emission control : Catalytic converter
Lubrication system : Wet sump
Transmission
Gearbox : Sequential 6-speed gearbox (RICARDO),
Transversally installed, straight cut, non synchronized
Differential : Mechanical limited slip differential
Clutch : Sintered metal clutch (AP), hydraulic
Transmission type : Front-wheel drive
Complete Gravel Suspension
Front axle : McPherson-struts, triangular wish bone, adjustable antirollbar
Rear axle : Trailing arm axle, adjustable antirollbar
Damper : ÖHLINS with adjustable fast-/low speed bump and rebound
Steering : TRW power steering
In addition : Kit Gravel
Brakes
Front : Ventilated brake disks
(Ø 300 mm gravel)
Pagid brake pads
Rear : Solid brake disks (Ø 280 mm)
ALCON aluminium callipers front and rear
Pagid brake pads
Polo 4 Super 1600 Asphalt
Specifications
Bore : 76,5 mm
Stroke : 86,9 mm
Capacity : 1598 cc
Transmission
Suspension
Brakes
(Ø 355 mm tarmac)
Pagid brake pads
Pagid brake pads
Nice pics, Maris. Man those are tuff looking lil beasties.
Dave
must...get...oz...racing...superturismo...wrc's
