Page 5 of 83 FirstFirst ... 345671555 ... LastLast
Results 41 to 50 of 821
Thread: Polo Picture Thread
  1. #41
    Jul 2005
    Quote Originally Posted by DaveMack View Post
    Eeewww ... why would you do that to the poor car?
    Dave
    I thought you'd like that!
  2. #42
    Jul 2005
  3. #43
    Mar 2007
    Now I like these ones, Maris.
    Dave
  4. #44
    Jul 2005
    Here is another couple for you Dave.
  5. #45
    Jul 2005
  6. #46
    Jul 2005
  7. #47
    Jan 2007
    God that looks frightening.
    Is that an AWD or just a front, either way that thing has massive road presence.
  8. #48
    Point Cook, Vic
    Specification
    Engine
    Cylinders: four in-line
    Fuel supply: sequential fuel injection
    Cubic Capacity: 1984 cm3
    Valve gear Soupapes: dohc, four valves per cylinder
    Ignition: electronic, Bosch MS3.1, with 128MB data logging
    Fuel requirement
    Engine Output
    Max Power ISO (kW): 210 Kw (282 Hp)
    Power peak: (r/min) 8250
    Max usable: (r/min) 8500
    Torque Peak: (r/min) 7000
    Transmission
    Forward speeds: 6
    Driven wheels: 4x4
    Front differential: Mechanical Limited Slip
    Rear differential: Mechanical Limited Slip
    Centre differential: Mechanical Limited Slip
    Clutch/Ambrayage: AP Racing twin plate
    Wheels and Tyres
    Gravel Rally wheels: 6.5Jx15 alloy
    Tarmac Rally wheels: 8J x 18 alloy
    Tyre size gravel: 195/65 R 15
    Tyre size Tarmac: 235/40 R 18
    Brakes
    Front calipers: 300mm ventilated discs with 4-piston Alcon
    Rear calipers: 300mm ventilated discs with 4-piston Alcon
    Hydraulics: dual circuit with balance bar
    Steering
    Type: Rack and pinion, power assisted
    Lock to Lock: 2 turns
    Suspension
    Front: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
    Rear: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
    Capacities
    Fuel tank: 70 litres
    Dimensions
    Overall length 3916mm
    Overall width 1800mm
    Ground clearance 170mm
    Wheelbase 2470mm
    Track front 1587mm
    Track rear 1587mm
    Weight
    FIA (minimum 1150kg) 1150kg
  9. #49
    Jul 2005
    Great post Tim, some interesting info..
  10. #50
    Point Cook, Vic
    i know this is the polo pic thread. But CHECK OUT THE VIDEO!?
    http://youtube.com/watch?v=9dHRcOTQ3Jc
    http://youtube.com/watch?v=hNNR-ZIDcas
