Results 1 to 10 of 821
Thread: Polo Picture Thread
    Jul 2005
    Jul 2005
    Jan 2007
    God that looks frightening.
    Is that an AWD or just a front, either way that thing has massive road presence.
    Point Cook, Vic
    Specification
    Engine
    Cylinders: four in-line
    Fuel supply: sequential fuel injection
    Cubic Capacity: 1984 cm3
    Valve gear Soupapes: dohc, four valves per cylinder
    Ignition: electronic, Bosch MS3.1, with 128MB data logging
    Fuel requirement
    Engine Output
    Max Power ISO (kW): 210 Kw (282 Hp)
    Power peak: (r/min) 8250
    Max usable: (r/min) 8500
    Torque Peak: (r/min) 7000
    Transmission
    Forward speeds: 6
    Driven wheels: 4x4
    Front differential: Mechanical Limited Slip
    Rear differential: Mechanical Limited Slip
    Centre differential: Mechanical Limited Slip
    Clutch/Ambrayage: AP Racing twin plate
    Wheels and Tyres
    Gravel Rally wheels: 6.5Jx15 alloy
    Tarmac Rally wheels: 8J x 18 alloy
    Tyre size gravel: 195/65 R 15
    Tyre size Tarmac: 235/40 R 18
    Brakes
    Front calipers: 300mm ventilated discs with 4-piston Alcon
    Rear calipers: 300mm ventilated discs with 4-piston Alcon
    Hydraulics: dual circuit with balance bar
    Steering
    Type: Rack and pinion, power assisted
    Lock to Lock: 2 turns
    Suspension
    Front: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
    Rear: MacPherson struts, Reiger dampers, Coil springs, fabricated wishbones, anti-roll bar
    Capacities
    Fuel tank: 70 litres
    Dimensions
    Overall length 3916mm
    Overall width 1800mm
    Ground clearance 170mm
    Wheelbase 2470mm
    Track front 1587mm
    Track rear 1587mm
    Weight
    FIA (minimum 1150kg) 1150kg
    Jul 2005
    Great post Tim, some interesting info..
    Point Cook, Vic
    i know this is the polo pic thread. But CHECK OUT THE VIDEO!?
    http://youtube.com/watch?v=9dHRcOTQ3Jc
    http://youtube.com/watch?v=hNNR-ZIDcas
    Mar 2007
    I WANT ONE! Just one ... is that too much to ask?
    Dave
    Jul 2005
    Polo 4 Super 1600 Gravel
    Specifications
    Engine Petrol engine, transversally installed, water-cooled
    4 –cylinder in line, 16 valves
    Bore : 76,5 mm
    Stroke : 86,9 mm
    Capacity : 1598 cc
    Power : 232 hp at 8750 revs
    Max Torque : 200 Nm at 6250 revs
    Engine management : BOSCH 3.1
    Emission control : Catalytic converter
    Lubrication system : Wet sump
    Transmission
    Gearbox : Sequential 6-speed gearbox (RICARDO),
    Transversally installed, straight cut, non synchronized
    Differential : Mechanical limited slip differential
    Clutch : Sintered metal clutch (AP), hydraulic
    Transmission type : Front-wheel drive
    Complete Gravel Suspension
    Front axle : McPherson-struts, triangular wish bone, adjustable antirollbar
    Rear axle : Trailing arm axle, adjustable antirollbar
    Damper : ÖHLINS with adjustable fast-/low speed bump and rebound
    Steering : TRW power steering
    In addition : Kit Gravel
    Brakes
    Front : Ventilated brake disks
    (Ø 300 mm gravel)
    Pagid brake pads
    Rear : Solid brake disks (Ø 280 mm)
    ALCON aluminium callipers front and rear
    Pagid brake pads
    Polo 4 Super 1600 Asphalt
    Specifications
    Bore : 76,5 mm
    Stroke : 86,9 mm
    Capacity : 1598 cc
    Transmission
    Suspension
    Brakes
    (Ø 355 mm tarmac)
    Pagid brake pads
    Pagid brake pads
    Jul 2005
    Jul 2005
