Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 53
Thread: Polo love and question
  1. #31
    Quote Originally Posted by TDIfan View Post
    Hello team WA
    We have 4 Polo owners now(I think)
    Should come out for some meets
    Can assist you engine wise, but happy to help if you need advice on many other mods
    Sounds good mate. Always good to meet like minded people.
  2. #32
    Apr 2014
    Perth
    Perhaps the Sat morning VW meet at elixir coffee in Claremont?
  3. #33
    Quote Originally Posted by Blue9N3 View Post
    Sounds good mate. What site is that on?
  4. #34
    Apr 2014
    Perth
    This one I think?
    Mostly flash Golf R's and S3's last time i saw it. The Pog that gets washed only when it rains looked distinctly out of place!
  5. #35
    Does anyone know if a low coolant level will activate the cel light? I've just riced out the pog with a pod filter and put a mini filter on the Sai. So I guess that could be the issue.
  6. #36
    nsw
    If what you've done with the SAI is put a filter on the end of the tube that used to plug into the air box (or even a shorter one more directly to the SAI pump inlet) then that should be ok. I believe coolant bottle level will generate an engine light. I left mine unplugged accidentally when I did my engine mounts and it brought up an error which I'm pretty sure would mimic a coolant level below the sensed minimum level.
  7. #37
    Nov 2012
    WA
    I get low coolant light every now and again due a small leak at water pump, doesn't cause a cel, just a low coolant light that flashes.
    08 9n3 Polo GTI
    Mods: heaps
  8. #38
    Run a diagnostic and came up with the recirculating air flap motor was faulty. Had a quick look and freed it up. Cleared the other old codes and now all good it seems to run better that the old codes are cleared(maybe just a placebo effect). Topped up the coolant just to be safe.
    On another note, man pods make the pog sound a lot more gruntier and no need for an aftermarket BOV.
  9. #39
    May 2015
    NSW
    Quote Originally Posted by Crossy85 View Post
    Vent to atmosphere BOV in my experience causes car to stutter during take off. I closed mine up and it the stutter went away so I would steer clear of a fully open BOV if you think of it later down the track.
  10. #40
    VWs aren't designed to run vent to atmosphere. The air is measured going through the MAF, if you let it out of the system, it screws with the maths.
    Coolant level doesn't trigger a CEL, it does put on a warning for the level.
