Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 53
Thread: Polo love and question
  1. #21
    Jan 2009
    Quote Originally Posted by Crossy85 View Post
    Well lads, the trial Ecu stage1 arrived this morning, I had to take the kids to school so I quickly put it in the car and waited till I got home to put it in. To my luck, the missus decided she was going out and so I installed it. Took it for a drive and wee'd a little bit in 2nd to 3rd gear. Holy moly what a difference, boosting up to 20 easing down to 15-17. Revs feel so much smoother, everything feels smoother. It feels how a turbo should. I was happy with it stock, but now I can't get the cheesy grin off my face. Now I have to work out a way of getting one permanently without her knowing any different. Wowsers I think I might go back for a drive.��
    Yeah it really transforms the character of the car. Unleashes the potential within.
    Daily: 2010 VW Jetta Highline
  2. #22
    SAMBB, transmission received, you sir are a gentleman and a scholar.
  3. #23
    Feb 2014
    Gold Coast, Queensland
    Well lads, the trial Ecu stage1 arrived this morning, I had to take the kids to school so I quickly put it in the car and waited till I got home to put it in. To my luck, the missus decided she was going out and so I installed it. Took it for a drive and wee'd a little bit in 2nd to 3rd gear. Holy moly what a difference, boosting up to 20 easing down to 15-17. Revs feel so much smoother, everything feels smoother. It feels how a turbo should. I was happy with it stock, but now I can't get the cheesy grin off my face. Now I have to work out a way of getting one permanently without her knowing any different. Wowsers I think I might go back for a drive.
    Once you've driven a stage 1 it makes you appreciate just how detuned they are in stock form
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  4. #24
    It really makes me appreciate the Polo even more. How "safe" is it, using the stage 1 for everyday use. In terms of driveline and internals? Has anyone had many problems? I only ask because once I started on the WRX, I had it at 15psi and stuff started going crazy, drive shaft, turbo, fittings, Pistons ect.
  5. #25
    My Polo had it's life limited by a Stge 1 tune. The tune ran very lean, which the tune you have in the loaner isn't. It also ate a turbo but in my opinion, that was due to bad servicing.
    There are many many Polo's running stage 1 and 2 tunes with no dramas at all. Certainly the engine itself is solid.
  6. #26
    nsw
    It'll be safe mate. I ran phase 1 even after adding a dump pipe, turbo inlet pipe and ported exhaust/wastegate allowing a lot more air to flow. Thats not an ideal state of affairs - I really should have been on phase 2 by then for far better driveability etc etc. So by rights if anything was going to expose the phase 1 tune for not being able to keep the fuelling up it would be that, but my air fuel ratios remained spot on and the car was flowing air equivalent to over 230hp. If your on phase 1 and more or less stock except for some inlet mods then it'll be safe as.
  7. #27
    Jan 2009
    My red polo has been driven hard pretty much it's whole life, making up to double the power of a stocko, still on stock internals. Stock power is about 90kwatw, stage 1 tune perhaps 120kwatw, with supporting mods closer to 130kw. Stage 2 (tune with downpipe and FMIC) around the 140kwatw. stage 3 (ko4 turbo) you're talking 150's to 170's atw.
    My daily polo used to be tracked quite a lot until I bought the red one 2yrs ago. There's plenty of polo's with 160,000kms running stage 2 and 3 modification daily and reliably. These are a stronger engines than the ej20 and 25's in the Subaru's, they can handle more abuse and aren't as sensitive to fuel starvation and knock as the boxer. The gearboxes, if not abused are fine, but the odd one has broken. Being fwd, adding power results in wheel spin unlike an AWD which transfer all the engine power into the gearbox and tyres, something has to give and it's usually not traction.
  8. #28
    Sweet as lads. Cheers for the replies and info. Puts my mind at ease now.
  9. #29
    Peregian Beach
    My 2006 Polo had a Stage 1 tune from Gavin with Seat intake since I got it at less than 40,000k's. At around 100,000k's I got a downpipe and exhaust and a Stage 2 tune. It now has 165,000k's on it and it still puts a smile on my dial every time I drive it.
  10. #30
    May 2012
    Perth, WA
    Hello team WA
    We have 4 Polo owners now(I think)
    Should come out for some meets
    Can't assist you engine wise, but happy to help if you need advice on many other mods
    06 Polo TDi
