Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: Polo Intake Thread
    Nov 2006
    Polo Intake Thread
    (holds hand up and waves)
    Yep, that's me....I'm the intake skeptic...show me the deltas...dyno, quarter times, lap times, 80-120 times...anything before/after...and I could become a believer.
    Have seen nothing yet, and am deeply fearful those "results" people talk about are largely the placebo effect arising from a little more induction noise and more audible turbo whistle. Suggestion : add a nice, big, noisy BOV; the effect will be even better!
    My rationale is this: we're dealing with a factory FI car here; the factory engineers have everything to gain in making the intake side of the engine as efficient as possible, so they do; whereas, on the exhaust and tune side, they are grossly hampered by environmental regulations and the need to ensure the engine handles a range of fuel qualities. The results are compromises in the tune and on the exhaust configuration. Body design constraints, weight and cost are all factors against most efficient intercooling, so there's possible gains there, too.
    That's why, IMHO, the best gains aftermarket are (in order) (a) chip (b) dump/exhaust (c) FMIC (provided it's not too expensive and heavy)....intake mods are a long way back, and personally I'd be spending money on brakes and handling for the Pog, before throwing any money at all in that direction
    I am happy to be proven wrong here -- it's just my opinion based on the evidence I've seen so far.
    Last edited by Timbo; 16-08-2007 at 02:43 PM. Reason: clarification...and to stick my chin out further ;)
    Jun 2007
    Polo Intake Thread
    Onya Timbo, it took considerable provocation to get you to come out of the woods
    Interesting theory on intake upgrades, I don't necessarily agree with it, but it should get us debating the pros/cons. All good
    To add my bit, there's one thing that shouldn't be overlooked, and that's the effect of higher and colder air charge that results from an intake upgrade (providing it's a good quality set up). If we're talking about fuel injection, then consider the MAF sensor and what it does when it senses higher volume and colder air, ie ECU responds by injecting higher fuel levels to match AFR = more power.
    Jun 2007
    "results are compromises in the tune and on the exhaust configuration. Body design constraints, weight and cost are all factors"..
    what makes you think the same compromises don't apply to intake design? surely they would - the pog's intake is compromised by trying to get around a big clunky battery that hogs the engine bay.
    Jun 2007
    consider it hijacked
    Nov 2006
    Quote Originally Posted by GT3
    Aaah....so what you're saying is that we should redesign the engine bay?!
    OK, so we pull out the battery, fit an Odyssey or similar, and install a BMC CDA...and what do we get (for our $600+)?
    Jun 2007
    Quote Originally Posted by Timbo View Post
    I'm not advocating for any intake upgrade option, there's plenty of options available, depending on the result you're after (and $$$ sure). A good way of experimenting is to try Kai's pod set up, it's cheap as chips and provides a very good insight into the effect modifying intake has (although heat soke is an issue, but that's why you shell out for a CDA, eg high air charge design). ..like most things, quality costs (usually).
    Dec 2006
    Gold Coast
    Quote Originally Posted by GT3 View Post
    I have since made a heat shield and it rocks.
    Feb 2007
    Brisvegas
    Quote Originally Posted by Kai View Post
    Any pics mate??? And how much did the cai set you back?
    Dec 2006
    Gold Coast
    Quote Originally Posted by VWindahouse View Post
    29.99 for airfilter
    2.50 for slice of heatsheild
    2.50 pvc pipe cold air piping
    Ill get photos in the morning...
    Most of you wont want to do it as it will be a defect and is very very dodgy but does the job alot better than the stock filter.
    Mar 2006
    South Hobart Tasmania
    I have used a pod heat shield set up in the polo but find with the new seat intake its just as good.
    Best thing about the pod was the smooth responce when u lift of the throttle without the pod u get a slight jerk. The turbo and DV were also alot louder.
    I got this idear from looking at a uk based company called jabba sport they use a similar set up on the ibiza.
    http://www.jabbasport.com/product_fu...?productid=73#
