Results 1 to 8 of 8
Thread: Polo Gti white smoke
    Jan 2009
    South Africa
    Posting for a friend of mine..
    "Hi
    I have a Polo GTI, 35000 on the clock. GIAC software and decat done.
    I have read a few threads on white smoke coming from exhaust when the car is idle. I have the same problem. But with me, when I am idling with the car on a hill/incline,then only do I get the white smoke coming out the exhaust. Its clouds and clouds of smoke, once I start moving it eventually clears up.
    No loss of performance, everything is fine, oil levels are good, I dont know what the problem is!! And I am having trouble explaining this to VW. Can you please suggest what it could be. I know it sounds wierd that when the car is idle on an incline it does this, but thats just it. Its also not all inclines, just slight incline/unevenly parked.
    Please help!"
    Feb 2008
    Perth, WA
    if it was an older car, i would point at piston rings
    Aug 2009
    did you check your coolant, white smoke could be evaporation of water?
    has it got a particular smell to it?
    Aug 2008
    Sounds like it's running too lean. It's normal to have white smoke when first started but this should go away after a few minutes.
    Cheers,
    John
    Aug 2009
    Could be a faulty turbo seal too.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Dec 2008
    South Africa
    sup all,
    u all know the issues i have had with my polo
    turbo was replaced at 43000 KM as it seals was gone, car used to smoke all the time
    the new turbo has 3500 KM on now, and yes when i park on an uneven/incline it did smoke once(almost in a mounting a curb position but car to the left )
    it definately aint the turbo, im not worried as i know it aint serious. but when i get a chance and some extra time i will be sending the car in for a few tests.
    in the mean time do you guys want to try park your pog in a similar position and let it idle and see if it smokes?
    if if does happen maybe this is something we can bring up with VW?
    Quote Originally Posted by Skywalker View Post
    "Hi
    Please help!"
    Where are you? Maybe we can advise somewhere to take a look instead of VW.
    Dec 2008
    South Africa
    Hi,
    we are both in South Africa..
