Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: polo gti turbo timer installation
    mdonohoe Guest
    Hi Guys,
    Sell the timer - it's a waste of time.
    I've had multiple turbo cars for the last 3 years or so and done over 100,000kms in all of them.
    Turbo timers in modern cars are not necessary. The manufactuers work long and hard to ensure that the engine can be shut off at any point and the turbo will still live a long, and possibly hard-driving life without failure.
    The single biggest failure point usually is flogging a car from cold(and I'm talking flogging the hell outta it). However, with modern oils, this is becoming less of an issue.
    However, the immobiliser only stops you from STARTING the car, not to keep it running. Essentially if you can start it, it will keep running. I've had this happen recently when my G/F had a Remote Start alarm installed in her liberty. The computer only requests clearance from the key for the first few seconds when it starts. After that, you can take it away.
    Thanks
    Matt
    Jul 2005
    A turbo is a turbo and they all keep spinning after the engine is turned off and they all recieve no oil when that happens.A timer can be fitted to cars with an immobiliser, it just needs a good electrician(I have one) . I have a timer on my turbo cars because K04's cost a lot of money and need oil to live!
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Feb 2007
    Brisvegas
    Quote Originally Posted by aprr32
    What do you think happens when the turbo timer turns the car off...?? engine stops and the turbo keeps spinning - your statement makes no sense!!
    A turbo timer is there to let oil circulate through the turbo bearings after a hard drive... if you have been flogging it the turbo is very hot. Turn the car straight off and the hot bearings heat up the surrounding oil and it and CAN causing warping / stress and resulting shaft play...
    Letting the engine idle for 1-2mins helps cooler oil flow to the turbo and cool it down before turn off avoiding the above mentioned isses. As someone already said ball bearings and improved constuction materials and methods lessen the chance of bearing failure after a hot turn off.
    You can always use the inbuilt turbo timer - you right foot... dont hit boost for 1-2mins before you stop the car.... no troubles bubbles!!!
    Jul 2005
    Turning the engine off with the turbo spinning at 80,000 rpm is gotta be worse than turning it off at 5000 rpm and thats why the timer lets you walk away so the turbo slows down with oil and water still circulating, isn't that kinder?
    Feb 2007
    Brisvegas
    Not really - turbo speed is a function of engine revs - turbo speed at idle after 15 sec will be the same as at idle speed after 2 mins...
    Turbo timer is there to let the engine run after turn off to circulate cool oil thru the turbo bearings. On the old plain bearing turbos if not properly cooled the bearings distort and introduce stress concentration points when the microstructure of the metal has changed due to repeated heating. On new tech turbos this isnt much of a problem due to advances in materials and bearing design.... i awlays let mine idle for 30sec - 1min after i get to my destination just to be safe
    BTW - straight after turn off there would be enough oil in the turbo bearings to account for a rundown to 0rpm due to forces present.
    Jul 2005
    Tell that to the Passat owners that kill a large number of turbos from oil coking and bearing siezure from not idling down.
    Feb 2007
    Brisvegas
    When you look at it the more you stress an engine component the more likley it is to fail - these turbos use boundry lubrication between rotating surfaces which is a very fine film of oil.... if you turn your engine off 6000rpm then yer maybe some damage can occur.... but who does that???
    IMO i have owned a turbo excel, 180, skyline and now the pog and have never had a timer installed cause they are a waste of >$200 when a bit of grey matter and your right foot can be employed. Buy yer if you flog your car adn turn it straight off then it causes stress but they are designed to be perfectly capable of running down from engine idle speed to a stop without damage
Similar Threads
  1. What do you love about your Polo?
    By SidGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 18-04-2019, 07:26 PM
  2. The life of a 2001 Polo 16v Mk5 6N2 Facelift
    By vwbonner in forum Polo Mk4 (6N & 6N2, 1995 - 2002)
    Last Post: 07-06-2010, 06:16 PM
  3. ECU Flashes for '06 Polo GTi
    By mdonohoe in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 13-04-2007, 08:46 AM
  4. Turbo Timer
    By shaneth in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 18-11-2006, 03:04 PM
