Results 1 to 9 of 9
Thread: polo gti traction control light
    Aug 2009
    my traction control light has turned on and wont go off. even when i press the button on the dash to turn it off. it used to turn in just for a few seconds when starting the car.
    I turned car off and on again, but the light remains lit.
    anyone else had this?
    06 Polo GTI
    standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
    Melbourne, Vic
    Indicates a fault with the system, get it checked by the dealer or someone with a vag-com cable
    Aug 2009
    I had it happen to mine once. I disconnected the battery, left the car sit for a few minutes, then re-connected it.
    All worked well afterwards... so I can only assume it was a sensor that tripped it off and it just needed the ECU reset to resolve it.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Aug 2009
    hey thanks for the suggestions, i did try the battery disconnect last night, but the dash light is still lit. so its plan b - go to a volks specialist and get it checked out.
    cheers
    06 Polo GTI
    Aug 2009
    quick update on what happened -
    took it to get scanned which revealed that my brake light switch was stuffed.
    which makes sense because my rear brake lights (but not the 3rd light) had failed to work.
    switch replaced, lights work again and dash light no longer on.
    end of saga
    06 Polo GTI
    Dec 2010
    jhb, south africa
    was it not the epc light? if so its very common here
    Melbourne, Vic
    much cheaper than abs failure hahaha
    Aug 2009
    yeah it was the traction control light ESP on the center console
    and in the gauge cluster it was the light of the little car doing a burn out, the one that normally blink when you spin the wheels or corner too fast.
    06 Polo GTI
    Jan 2009
    blankedy
    Ah, the one you press to have fun...
