Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 84
Thread: Polo Gti - Pod Vs Seat/bmc
  1. #61
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by Petrina Polo View Post
    BUT...
    Does the increased temp of the air through a pod go through the MAF sensor hottor and it pulls timing??
    despite what the intercooler is doing..
    No... the ECU have other temp sensor at the intake manifold, behind the throttle body.
    SILVER TEAM
  2. #62
    Dec 2008
    Curitiba/PR, Brazil
    Let the intercooler do his job!
    Quote Originally Posted by Blitzen View Post
    Charge air will ALWAYS be hotter between the compressor of the turbo and the inlet for the intercooler...This is a given, because as air is compressed, it heats up, there fore, a pod filter will make almost no difference to intake temperature after the turbo, but before the intake manifold.
    The charge air between the intercooler (of a car fitted with a bigger intercooler...Ie Forge, APR...) and the intake manifold should be cooler than ambient temperature due to the fact that most of the time the engine is in operation, the car is moving forward, and the airflow through the intercooler is rushing through there, cooling better than ambiant.
    SILVER TEAM
  3. #63
    Jan 2009
    WEst Sydney
    in my (limited) opinion:
    The issue with the Pod filter putting in hotter air is that the hotter air won't be as compressed by the turbo. Thus less boost pressure.
    By the time it goes through the cooler, it won't be overly different temperature (depending on a lot of variables), but it will be less compressed.
    My boost gauge shows the same boost on both scenarios..?? Maybe its compressed different rates but is it negligible.
  4. #64
    Jan 2008
    Ferntree Gully
    Boost pressure is measured post intercooler... and as the wastegate is operated via this measurement, it wont open until the desired boost level is hit.
    If that means running the turbo harder, so be it.
  5. #65
    Jan 2009
    WEst Sydney
    So anyone hit the dyno with both setups?
    does putting the pod filter in the airbox make it worse as you use a 90 degree elbow bend? is it better to leave it straight off the maf?? Air flows through straighter.
  6. #66
    It's pretty hard to measure air intake gains on a dyno - the fans (and we have used a few) only emulate from 80 - 160 kmph of air, and this air is only hitting part of the frontal area of a car. Mostly on a dyno you are trying to get airfolw over the radiator & intercooler - not directing it straight at the intake! You can see a huge difference in MAF reading when testing on the road (closed track of course!)
  7. #67
    Jan 2009
    sunshine coast
    hey guy, how much would it cost me for a cold air intake on the polo? i know the lite wieght battery costs around 200-300 and i think the intake on your site was around 650 ish?. pm me if you wanted to.
    on another note if i go through with this ill be selling my seat intake, my stock battery and my k and n filter, if anyone is interested.
    personally i always thaught the main problem with the pod was sucking hot air from the engine bay offsets the bonuses of having higher flow. the only real bonus is noise imo.
  8. #68
    Mike, you are pretty close with that estimate - just a bit of labour to fit & fabricate new battery hold down stuff & shift some cables around!
  9. #69
    Oct 2006
    I have the small battery for sale
  10. #70
    Jul 2007
    Auckland, NZ
    Will take your k n n if you decide to sell it. :0)
    Just so hard getting it in nz for good price.
    Good luck
    Quote Originally Posted by mikepologti View Post
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
