Results 1 to 9 of 9
Thread: Polo GTI with MK1 Audi TT Brakes
    Jan 2010
    I've done some searching and can't really find a definitive answer...
    I've sourced a set of front MK1 Audi TT brakes complete - rotor, caliper, pads, etc. I want to use these to replace my 06 Polo GTI brakes, can anyone confirm that these are a direct bolt on?
    Thanks
    2007 MY08 VW Golf MKV R32 Blue 6M 3-Door
    2006 9N3 VW Polo GTI White 5M 3-Door
    Oct 2010
    Mont Albert, VIC
    yes, as long as you also have the TT brake carriers as well.
    The polo gti brake hose might be a little bit to short for the TT caliper, I am not 100% sure.
    cheers
    GT Sport TDI Black Pearl
    Jan 2010
    Thanks for that, I'll make sure I get the carriers as well.
    Aug 2007
    Yeah if you do it get the lot, same goes for the rear, ive done a few fronts and a set of rears.
    Jmac
    Alba European
    Aug 2007
    Jmac
    Alba European
    Sep 2006
    Quote Originally Posted by Jmac View Post
    Jmac
    Do you know what the rears were Jmac, do they have to be of a 225 or any TT, do you know if there is differences between TT180 TT225 TT3.2
    Oct 2010
    Mont Albert, VIC
    Quote Originally Posted by vwthunder View Post
    the rear from a TT225 is what you want, because TT180 uses the same 232mmx9mm solid disc as the polo gti.
    With the 225, it is bolt on plus splash guard if you get it from a FWD. Otherwise with quattro 225, you will need 6mm spacers.
    Sep 2006
    Quote Originally Posted by kmli5 View Post
    Thanks, guessing it is not easy to come by
    Oct 2010
    Mont Albert, VIC
    I have seen reconditioned/new complete set of rear set up over at UK ebay.
    Check this out:
    VW/AUDI/SEAT/SKODA 256mm REAR BRAKE CALIPERS DISCS&PADS on eBay (end time 11-Feb-11 22:33:29 GMT)
    cheers
