Originally Posted by
sambb
The stock side mount IC had the MAP sensor mounted directly onto the outlet tank. That's not done by any of the aftermarket IC peoples so you need one of the pipes that runs between the IC exit and the throttle body to have a MAP mounting boss in it. Some manufacturers have t as part of the kit, others don't. You can source the boss's separately but you'll then need that to be welded to the pipe (in a position that the stock MAP loom/plug can reach would be easiest).
The MAP sensor is manifold air pressure. It measures boost basically. The inlet temp sensor is in the throttle body on the plenum side of the throttle plate. Its definitely needed so look into the MAP sensor mounting side of things for sure.
