Originally Posted by
Evaded Motorsport
kaanage
How different are the hub and carrier to those of the MkIV Golf with the 280mm rotors?
Completely as far as I am aware.
I should have said 288mm rotors.
Does anyone know if the front hubs and carriers from MkIV Golfs with 288mm brakes are the same as those used on the 9N3 GTi?
Resident grumpy old fart
