Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Polo Gti Gearboxes
    Aug 2007
    Polo Gti Gearboxes
    Just thought i would throw this in as it is quite a hot topic amongst the Pog clan and would be the first thing i would recommend trying even if you dont experience the fault as it makes the gearbox change as smooth as the preverbial.
    Guys and gals!! I had a Gti Present with a gearbox fault to the point i thOught it was going to need syncros. Crunching every shift. Suspect syncro hub / baulk ring failure. Had a ponder and remembered an old fix on the 02A gearboxes , which is a cable shift similar to the Polo. Now i had a few Cupras with the ABF unit and 02a box doing the same. Fix was drain the oil and fill with 2 litres of Redline MTl which has poly and has SUPERB friction properties. I did this to the Polo Gti in question and ran the vehicle for about 50ks and after that the thing was quiete and was shifting VERY smooth. No crunching up or down the box. Again an old fix proves to be one of the best.
    I thoroughly recommend you try this if you are having any issues with your Polo Gearbox.
    Jmac
    Alba European
    Jun 2006
    Orange NSW
    Might use redline for the 16v box when i put it into the mk1 if you reckon its that good.
    Thanks for the info dude.
    Sep 2006
    Brisvegas
    Yeah mate good work on the writeup. You can have a look at mine when its in and see if it needs doing. btw you have pm.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    Oct 2006
    I used redline in my Skyline. Made it feel a lot better
    However I thought redline was no good for VW boxes?
    Jan 2008
    Melbun
    sorry slightly off topic but jimmy what gb oil do you recommend for my notchy as hell mk5 gt tdi? cheers pal
    2x Caddy, 1x Ducato
    Aug 2007
    Like i mention made a huge difference and this was the fix back in the day on the Cupras mate with no dramas.
    Jmac
    Alba European
    Jan 2008
    I have never seen Redline oil before, not that I have looked. What is a bottle of the stuff worth and is it available at all major spare parts shop?
    Aug 2007
    Redline is available at present in Coventry Auto parts, Bursons, Autopro and some Autobarns. Your boutique specialists im sure will stock it as well and you can expect to pay $35 per litre and you need 2
    Jmac
    Alba European
    Jul 2007
    Auckland, NZ
    Redline transmission oils are very well known for its good performance. Even used in automatic performance machines... which I used for last time.
    It's good oil, only bad thing I heard was my friend who knows his car well, put redline oil, and was so ?thin after a couple of track days, he now lost his 3rd gear. His car is 350Z. He said he'll try different oil next time...
    Oh well, but yes general consensus is 'redline rules'.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Aug 2007
    Yeah it has come a long way mate, that cupra fix i did back in 95 kinda time frame, so i would say it has been tested more since.
    Mischa mate give this a try too man for the sake of $70 its worth a try.
    Jmac
    Alba European
