Speaking from experience relocating the battery to the boot is nothing but trouble. Also it would be cheaper to just get a compact battery for the original location as by law you need to have a fully sealed battery if it is mounted internally (boot included). This means you'd spend a few hundred on the relocation kit then about $400 for an Optima battery (or similar).
What about a side mount kit for the standard location (mount lengthways). Straight away you'd have an improvement but if you wanted to get a compact battery also then you would have massive amounts of room.
Wha about if we fitted a large collector behind the headlight (lots of cool air comes through her as far as I am aware), pipe it in between the engine and battery into an enclsoure that housed a pod filter and adapted to the stock MAF...
Alternatvily, you could fit the collector behind the headlight and run it between the battery and the LHS guard, which may require a bit of work to miss the water washer filler, or come up with some kind of battery relocation kit which swung the battery roung 90deg as this would allow a bit more room to work with...
