the manual doesn't show a torque spec, but going by the size of the bolt it should be about 70nm- I just did it up tight...
Hey all,
In the process of installing a new powerflex dogbone insert for my 9n3 GTI.
Was just wondering what are the torque specs for the mount.
e.g. the 2 bolts to the transmission and the main insert bolt to the subframe.
Cheers, Nick.
In the ECS clutch kit it says the two into the gearbox are 50 Nm. The one into the cross member is only like 25Nm from memory because the threads are way smaller than the hex head.
Awesome, Thanks guys.
