Page 7 of 7 FirstFirst ... 567
Results 61 to 68 of 68
Thread: POLO GTi OR COOPER S??
  1. #61
    Melb, Vic
    anybody with a revo remap here? just wondering how much PSI they run in the polo gti. hopefully not 22PSI. thats a bit high isnt it?
  2. #62
    Do many people with boost mods run Electronic Boost controllers?
    Does a 22psi remap get much boost spike in cold conditions?
  3. #63
    Nov 2006
    Mine's a REVO -- ^^ see MACCAA's response
  4. #64
    From another K03 / boost thread question:
    http://www.vwwatercooled.org.au/newf...8&postcount=12
  5. #65
    Oct 2006
    From memory my APR'd Polo would spike to 1.4bar.
  6. #66
    Not if everthing was in good working order - .2 bar overboost is about it (~ 19psi) If you are making more than that, I would pop in to your tuner & see whats wrong (assuming you have no other boost control devices in line)
    Spiking beyond 20psi doesn't do anything for your power curve & driveability. What you need is a nice sustained boost curve to make it fast & driveable.
  7. #67
    Jun 2007
    Brunswick, Victoria
    hmmmm. looks like I have to see my closet APR dealer because my dyno graph shows peak about 20 psi!
    Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
    "The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
  8. #68
    Quote Originally Posted by Koz View Post
    If thats just the vac refernce of the dyno, thats fine, normally they plug it off the fuel pressure regulator or the manifold at a dyno which can vary a few psi either way.
    Since you have a Polo, you have a boost sensor which reads actual boost (= or - .005 %) - you simply have to data log this. Its pretty simple - requested boost vs actual boost and they should run pretty close to each other.
    Log yours & print the plots in excel - I just did a quick web search & here are some for you. If you need it checked out, drop it back to your APR dealer & he will sort it for you - no problems at all.
    http://www.seatcupra.net/forums/showthread.php?t=64753
