Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Polo GTI - Boost Gauge Wiring
    Dec 2007
    South Africa - KZN
    Hi all, this is my first post in this forum Been reading old threads, there is some very informative info and knowledgeable members.
    Today I decided to install a boost gauge in my GTI, it all went smoothly after a few searches on the forum, however I've had some trouble with the wiring for the lighting. I know how to remove the headlight switch but I'm unsure which wires I should tap into so the gauge lighting will work with the rest of the instrument cluster. Any help or advice would be appreciated.
    Thanks,
    hail10
    Jul 2007
    Gold Coast
    Quote Originally Posted by hail10 View Post
    Thanks,
    hail10
    i just hooked mine up too.
    use the stereo cable for pos+ power, ground from underneath of the top centre tray on the dash.
    and illum i use the cable from ciga light. remove the two screw and lift the centre plastic panel up to gain access to the cables.
    good luck
    use the ciga cable.
    vanilla5 Guest
    just paid a mechanic to install it properly.
    Dec 2007
    South Africa - KZN
    @s1831559 - Thanks for the advice, I'm gonna go try it out asap
    @vanilla5 - Unfortunately were I live the mechanics are clueless, safer to do it myself
    Jul 2007
    Gold Coast
    hail10. honestly i look after my car better for sure, unlike most mechanics. i had too many awful past exp on how people treat my beloved cars.
    any q just pm me.
    Mar 2007
    Can highly recommend one of our own ... Jimmymac on this forum (in Bris). (He's looking after my 'baby' while I'm in NZ.)
    Of course ... that doesn't really help our Sth African friend.
    Dave
    Dec 2007
    South Africa - KZN
    Thanks alot for all the help guys, I do appreciate it. Finally finished the install today and its working perfectly. I'm very pleased with it. Was easier than I expected, thanks to the good guidance. I'm glad I did it myself, it helps to learn a few things about the car as well as gives a sense of satisfaction with a job well done.
    Regards,
    hail10
    Mar 2006
    South Hobart Tasmania
    Can i ask where you ran the boost line throught the fire wal.l I am thinking of installing one too did have a look but cant see any holes? Any pics would be awsome. Cheers Rob.
    Dec 2006
    Gold Coast
    Quote Originally Posted by PoloGTi View Post
    Passenger Footwell has one.
    I ran mine through there into my bov line.
    Jul 2007
    Gold Coast
    i ran mine through the rubber stopper on the side, near the door hinge.
    steps:
    1. remove front left wheel
    2. un-screw plastic wheel acrh cover
    3. un-screw & remove another plactic cover near door hinge
    4. run the cable thru the front of left fender near the headlight (in the engine bay), thru the wheel arch.
    hope this will help
