Quote Originally Posted by hail10 View Post
Hi all, this is my first post in this forum Been reading old threads, there is some very informative info and knowledgeable members.
Today I decided to install a boost gauge in my GTI, it all went smoothly after a few searches on the forum, however I've had some trouble with the wiring for the lighting. I know how to remove the headlight switch but I'm unsure which wires I should tap into so the gauge lighting will work with the rest of the instrument cluster. Any help or advice would be appreciated.
Thanks,
hail10
i just hooked mine up too.
use the stereo cable for pos+ power, ground from underneath of the top centre tray on the dash.
and illum i use the cable from ciga light. remove the two screw and lift the centre plastic panel up to gain access to the cables.
good luck
use the ciga cable.
