Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 54
Thread: polo gti 9n3 stage 1 flat and gutless
  1. #41
    Quote Originally Posted by barcode View Post
    Just thought I'll update, car is running great no problems, just waiting for engine and dog bone mounts to arrive, a xmas job for sure.
    One thing that did stand out in the traffic today was the car while in neutral waiting at the lights, all of a sudden the revs just started to go up all by themselves to about 1500rpm while not touching the accelerator for a few secs say 5 sec max then it dropped to the normal 700rpm.
    Anyone know why it did this, its happened twice now in the past week! no error codes or cel reported
    Also I have put the drop in K & N back in no error codes to date 32 bank reading -1.1 -2.3
    Radiator fans cutting in probably, a pretty extreme increase but I wouldn't be worried.
  2. #42
    Nov 2015
    sydney
    tnx Gavin, both times yes it was hot phew. Loving this polo the more I drive it, poor mazda6 today, its like a little midget killing a sumo lol
  3. #43
    Oct 2013
    i had my car for almost a year now and still loven it more and more everyday they need a lsd lol
    My Beast: 06 Polo GTI~White~Milltec CBE~APR V2 Tune~SuperPro Bushes~WhiteLine FSB~Phenolic Spacer
    2nd Beast: 02 Audi S3~Stock
  4. #44
    Feb 2014
    Gold Coast, Queensland
    Quote Originally Posted by HAR80N View Post
    LSD? No problem, just save $4K
    2006 GTI Polo - Big Turbo Build - Louis19's Build Thread
  5. #45
    Oct 2013
    Quote Originally Posted by louis19 View Post
    hahahah chump change i would love to know what 1st gear felt like with out wheel spin wish the tuners could do boost per gear like the hondata ecu's
  6. #46
    Nov 2015
    sydney
    Hi all
    managed to do some vagcom logs today, just wondering if anyone knows what the maf logs should read
    I was getting this, but it would seem too low
    Group B: '002 Group C: '003
    RPM Load Inj. On Time Mass Flow RPM Mass Flow Load Ign. Timing
    TIME TIME
    STAMP /min % ms g/s STAMP /min g/s % °BTDC
    0.61 720 21.8 2.04 2.92 0.02 760 2.89 1.2 0
    1.5 720 21.8 2.04 2.89 0.91 760 2.89 0.8 0.8
    2.42 1280 42.9 4.76 10.42 1.82 720 2.89 0.8 0.8
    3.32 1120 55.6 6.12 13.36 2.72 1440 12.31 8.2 24
    4.23 1560 60.9 6.46 18.5 3.63 1080 12.56 10.6 12.8
    5.14 1960 18 1.7 5.39 4.53 1800 22.92 16.5 23.3
    6.04 1280 63.2 7.48 18.39 5.44 1640 4.33 2.4 -4.5
    6.95 1680 82 9.18 27.97 6.34 1400 21.81 67.1 15.8
    7.85 2120 97.7 10.88 40.72 7.25 1800 31.61 70.6 12.8
    8.76 2640 112.8 11.22 61.69 8.15 2280 35.33 20.8 20.3
    9.66 2320 12.8 1.36 6.22 9.06 2840 69.22 88.6 9
    10.57 2040 76.7 8.84 34.28 9.96 2040 4.56 3.9 30
    11.47 2240 88.7 10.88 42.31 10.87 2080 32.39 20.8 19.5
    12.38 2400 68.4 7.14 33.97 11.77 2280 40.72 24.7 8.3
    13.28 2600 97 10.54 51.81 12.68 2480 34.67 19.2 22.5
    14.19 2960 144.4 15.64 87.39 13.58 2720 62.53 98.4 19.5
    15.09 3360 188 21.76 120.81 14.49 3080 103.03 100 0.8
    16 3800 177.4 21.08 127.58 15.39 3560 127.03 100 0
    16.9 4160 172.2 20.06 135.75 16.3 3920 132.58 100 3
    17.82 4520 165.4 19.38 140.53 17.22 4280 137.69 100 7.5
    turbo psi seems ok
    Group A: '115
    RPM Load Absolute Pres. Absolute Pres.
    TIME spec actual spec actual
    STAMP /min % mbar mbar psi psi
    0.31 720 21.8 990 990 0 0
    1.21 720 21.8 990 990 0 0
    2.12 800 30.8 990 990 0 0
    3.02 1360 48.1 990 990 0 0
    3.93 1320 57.9 990 1020 0 0.435
    4.83 2080 66.2 990 1090 0 1.45
    5.74 1440 22.6 990 1000 0 0.145
    6.64 1520 78.2 1310 1060 4.64 1.015
    7.55 1960 92.5 1300 1210 4.495 3.19
    8.45 2440 102.3 1720 1310 10.585 4.64
    9.36 2640 20.3 990 1240 0 3.625
    10.26 2000 49.6 990 1010 0 0.29
    11.17 2120 66.9 1030 1180 0.58 2.755
    12.08 2360 70.7 990 1270 0 4.06
    12.98 2520 72.2 1150 1210 2.32 3.19
    13.89 2840 128.6 1920 1650 13.485 9.57
    14.79 3240 179.7 2150 2280 16.82 18.705
    15.7 3680 182.7 2180 2300 17.255 18.995
    16.6 4040 174.4 2220 2190 17.835 17.4
    17.52 4400 166.9 2130 2160 16.53 16.965
  7. #47
    Hi all
    TIME TIME
    turbo psi seems ok
    Group A: '115
    Log 002 031 099
    003 020 022
    003 115 118
    in 3rd from 150 revs and do a screen shot or something so you can read it. Email me if you want. it's in my sig.
  8. #48
    Nov 2015
    sydney
    Log 002 031 099
    003 020 022
    003 115 118
    email sent to gmail, good luck understanding all that and thank you for your troubles.
  9. #49
    Logged at logs, you missed some of the blocks out. Didn't get the 031 lambda, which was important. It's flowing air for 205hp at the crank. Which is on the money really for a stage 1.
    You also missed the 118 block so no intake temps to see either. Boost look ok though, decent spike before settling back to requested.
    In the ignition logs I can see it's pulling timing, so might want plugs or the gaps tightening up. Not normal to see timing pulled on a Stage 1 tune IMO and experience.
    This might be what you can feel when you drive it.
    Run them again and check you have all the blocks in and have hit GO for each line before doing the run.
  10. #50
    Nov 2015
    sydney
    thank you for your comments, apologies for missing some logs I was half asleep at 130am when I read your post and got out of bed in pyjamas running the logs
    I had a feeling its the god dam plugs too, would going one step colder help, I did order the bkr7eix ones but after a week the tips where covered in a white thick frost looking thingy only on 3 of the plugs the 4th one cylinder 2 had no white on its tip it was brownish to greyish, so I went back to the pfr6q
    when I installed the bkr7eix plugs I didn't check the gap thought through factory they should be ok going to go and get a gapping tool now, also can the r8 coils have any effect on this?
    what gapping is good for stage1 0.28?
    tnx
