Results 21 to 30 of 32
Thread: Polo Gti 1/4 mile slips
  1. #21
    Apr 2006
    VW Race HQ - Sydney
    Firstly good onya for going out there with a stock polo on a hot night and having a go .
    The times are pretty good , it looks like the launch is where your loosing time , if it wheelspins too much lower your tyre pressure slightly . Getting the launch right is critical in getting a good et it doesnt affect your mph as much though . Ive found that launching it around 3500 rpm is probably the best rpm for a stock turbo and gently slipping it so it doesnt grab too hard . That way its right on boost when it does grab , also I would be leaving it in 3rd across the finish line , you loose about .3 sec on a gear change ! But overall thats a good result on a hot night . With a perfect launch and the temperature around 20 you should dip into the low 15's . Also a bit of weight reduction helps too !!! . Looking forward to seeing some more timeslips soon
  2. #22
    Sep 2006
    Tweed Heads
    Quote Originally Posted by Bug_racer
    Hoyhoy.
    Shaneth.
    This statement is spot on. My best run was the only time I hung onto 3rd peg. Also dropped the tyre pressures down to 25 lbs & the revs on take off, after the first run which was all wheel spin.
    P.S. At Eastern Creek the reaction times are excluded from actual times on the amateur nights.
    Hooroo.
  3. #23
    Dec 2006
    Gold Coast
    Speaking of tyres pressures, what would you recomend for normal driving.
  4. #24
    Sep 2006
    Tweed Heads
    Quote Originally Posted by Kai
    Hoyhoy.
    Kia here is what Shaneth & Myself come up with earlier on.
    Quote:
    Originally Posted by shaneth
    Well went to the servo to check my tyre pressure and found that they dont use BAR incriments on there gauge so i have done a bit of research to save everyone else.
    Tyre Bar Pressure PSI pressure
    Front 2.8 40
    Rear 3.2 46
    Now according to Michelin uk site it says to add 5 psi to the cold recommendation if your tyres are hot.
    I hope this helps
    Hoyhoy.
    Shaneth, These figures are O.K. if you have 5 passengers & luggage.
    I myself have'nt had anyone in the rear seat as yet, so then the figures change a bit.
    Fr. 2.6--38lb. [ As recommended for 2 passengers.]
    Re. 2.4--35lb. [ " " " " " .]
    As this little girl is mine & the wife has her own car, I changed the pressures even to these figures.
    Fr. 2.5--36lb. [ This also helps with the torque steer.]
    Re. 34lb. [ " " " " " " " .]
    __________________
    Hooroo.
  5. #25
    Nov 2006
    ha, i ran at calder park last fri as well, stock as a rock and 34 psi in the front tyres lol reaction time lol, 15.4 at 88 mph... i'm ok with that... 4 now. The other lane is my cousin in his 94 wrx, didn't even launch and still pull 14 flat bastard lol. Traction control is off, full weight with 3/4 tank.
    The next day i put it on the dyno at a dyno comp at a local shop, bit wierd as its lower than i expected, may be the dyno setup that day. the same wrx got 152kw@14psi at all 4.
    Mine...
  6. #26
    Nov 2006
    Brisneyland
    15.4 woah! excellent times for a stocko GTIJNR!
  7. #27
    Quote Originally Posted by GTIJNR
    Mine...
    21KW drivetrain loss is excellent. What did you think it should be?
  8. #28
    Jul 2006
    melbourne
    Mine...
    My other half (blue XR5) said he chatted to you He called me up after and said I should come down and run mine but I was busy
    gtigrl want to go faster
    2006 Polo GTI
  9. #29
    Sep 2006
    Brisvegas
    I would have thought 93 would be about right but we all know what dyno's are like you could have taken it down the road 10 minutes after and gotten the 93kw reading. Unfortuneately dynos cant be relied upon 100% for power figures. In fact my Last car which was a 1993 corolla had 86kw@w and weighed in around 1050kg and the best i could do was 15.9 and it had lsd as well. What im getting at is that its all relitive.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  10. #30
    I just got the temp APR chip and the best I can manage for 0-100 is 6.3-6.4 sec....
    also I went to the drags last night..... toooo much wheelspin... even when shortshifting.... ran a 15.1 at 94mph.... but wheel spinning all way thru second gear...lol
    any suggestions on launch to reduce wheelspin?
Similar Threads
  1. What do you love about your Polo?
    By SidGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 18-04-2019, 07:26 PM
  2. The life of a 2001 Polo 16v Mk5 6N2 Facelift
    By vwbonner in forum Polo Mk4 (6N & 6N2, 1995 - 2002)
    Last Post: 07-06-2010, 06:16 PM
  3. Another new Polo GTI owner....
    By theStainRemover in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 06-08-2009, 10:33 AM
  4. ECU Flashes for '06 Polo GTi
    By mdonohoe in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 13-04-2007, 08:46 AM
  5. Polo Newbie
    By Arnie in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 10-02-2007, 10:12 AM
