[9N-9N3]
Exterior:
Body kits
http://www.vwwatercooled.org.au/newf...ad.php?t=11376
Front Splitter
http://www.vwwatercooled.org.au/newf...ead.php?t=4801
Exterior Lighting:
Polo 9N3 Head Light Bulb Changing Guide:
http://www.vwwatercooled.org.au/newf...ad.php?t=10756
Polo 9N3 Rear Tail Light Removal.
http://www.vwwatercooled.org.au/newf...ad.php?t=10883
9N3 Light Globes list
http://www.vwwatercooled.org.au/newf...ead.php?t=9442
HID Disscusion
http://www.vwwatercooled.org.au/newf...ad.php?t=11941
Interior:
Trim Removal
http://www.vwwatercooled.org.au/newf...ead.php?t=8102
Polo Stereo Info
http://www.vwwatercooled.org.au/newf...ead.php?t=5808
http://www.vwwatercooled.org.au/newf...ead.php?t=2929
Polo Tool Kit Reassembly
http://www.vwwatercooled.org.au/newf...ead.php?t=6897
Polo 9N Pollen Filter Clean / Change.
http://www.vwwatercooled.org.au/newf...ad.php?t=10755
Interior Lighting:
Suspension :
DIY - 9n3 Forge Strut Brace Instal
http://www.vwwatercooled.org.au/newf...ead.php?t=8849
How To Fit The Whiteline Rear Sway Bar
http://www.vwwatercooled.org.au/newf...=rear+sway+bar
Polo Suspension
http://www.vwwatercooled.org.au/newf...ead.php?t=1396
Brakes:
Standered brake pad options:
http://www.vwwatercooled.org.au/newf...22&postcount=6
http://www.vwwatercooled.org.au/newf...aded#post44153
R32 334mm upgrade
http://www.vwwatercooled.org.au/newf...ad.php?t=6745&
Audi S3/TT 312mm Brake Upgrade
http://www.vwwatercooled.org.au/newf...ad.php?t=2648&
DBA 312mm Rotors worth it or not
http://www.vwwatercooled.org.au/newf...ead.php?t=7322
Drivetrain :
Power Steering fluid location.
http://www.vwwatercooled.org.au/newf...ad.php?t=11075
APR Dog Bone Mount
http://www.vwwatercooled.org.au/newf...ead.php?t=9842
LSD Options.
http://www.vwwatercooled.org.au/newf...ad.php?t=12607
Transmission :
What's a good rpm to shift to save fuel?
http://www.vwwatercooled.org.au/newf...ead.php?t=3063
Have you had gearbox problems with your Polo GTI?
http://www.vwwatercooled.org.au/newf...ead.php?t=8246
Wheels and Tyres:
Tyre Discution
http://www.vwwatercooled.org.au/newf...ad.php?t=11047
http://www.vwwatercooled.org.au/newf...ad.php?t=11939
Removing Rear Wheel
http://www.vwwatercooled.org.au/newf...ead.php?t=7486
DIY Wheel Refurb
http://www.vwwatercooled.org.au/newf...ead.php?t=8860
Intake and Exhaust:
Seat Air Intake Installation
http://www.vwwatercooled.org.au/newf...ead.php?t=6160
Seat Air intake test.
http://www.vwwatercooled.org.au/newf...ht=seat+intake
Forge TIP Discusion
http://www.vwwatercooled.org.au/newf...ight=Forge+TIP
What gains are to be made with an exhaust system?
http://www.vwwatercooled.org.au/newf...highlight=pipe
Engine:
-1.8T
Noise When First Opening The Car Door.
http://www.vwwatercooled.org.au/newf...ad.php?t=20212
Turbo Bolt Problem
http://www.vwwatercooled.org.au/newf...ad.php?t=10059
http://www.vwwatercooled.org.au/newf...ad.php?t=10584
Polo GTI - Do you have to use 98 RON?
http://www.vwwatercooled.org.au/newf...ead.php?t=3172
Fuel Consumption ?
http://www.vwwatercooled.org.au/newf...ead.php?t=2894
Engine Oil ?
http://www.vwwatercooled.org.au/newf...ead.php?t=2506
Boost Gauge Wiring
http://www.vwwatercooled.org.au/newf...ad.php?t=11273
http://www.vwwatercooled.org.au/newf...ad.php?t=35780
