Results 1 to 4 of 4
Thread: Polo FAQ, DIY And Info: Look Here First.
    Mar 2006
    South Hobart Tasmania
    Exclamation Polo FAQ, DIY And Info: Look Here First.
    PLEASE BE PAITIENT WHILE I FINISH UP DATING THE FAQ.
    If you would like anything added please pm me and ill try to get it in the list to make it easy cheers Rob.
    Interchangeable Parts Register... Or "what we can pinch from other makes!"
    Sections that are coverd for all polo models are:
    Exterior - Bodykits, Bumpers, Side skirts, Valances, Badges, , Wipers, Mirrors, Windows, Sunroof
    Exterior Lighting - Headlights, Tailights, turn signals, side markers
    Interior - Rattles, squeaks, shift knobs, steering wheels, trim kits, gauge clusters, gauges, seats, alarm, heating and A/C, interior disassembly,Audio/Video, Subwoofers, MP3 Players, GPS, Keyfobs, Alarm modifications, window controllers, cruise control
    Interior Lighting- Globes,
    Suspension - Shocks, Springs, Coilovers, Swaybars, Strutbars, Stressbars
    Wheel and Tire
    Brakes - Calipers, carriers, rotors, pads, brake light switch
    Transmission - Automatic and Manual, Starter
    Drivetrain - Items/Issues that are common across drivetrains (Engine/Transmission). Fault codes, coilpacks, 02 sensors, EDL and ASR, Oil, battery, engine mounts, bushings, bearings and hubs, axles, fuel filter.
    Intake and Exhaust - Cold Air Intakes, airboxes, CAI's, filters, exhaust systems and components.
    [General.]
    Polo The Story. Everything you ever wanted to know.
    Present: Polo - The Story
    Idiots Guide to Chipping
    Polo Dyno Day Brisbane, Saturday August 25th
    Pog wars - episode i
    Polo 9n3 Performance Tracking Thread
    VW Key disassembly
    Volkswagen Key Disassembly
    Polo Reviews.
    http://www.timesonline.co.uk/tol/dri...icle639727.ece
    IOL Motoring | IOL.co.za
    http://www.drive.com.au/Editorial/Ar...arison ID=748
    http://www.parkers.co.uk/cars/review...spx?model=1517
    Volkswagen Polo GTI Car Review – MotorPoint
    http://www.webwombat.com.au/motoring...gti-review.htm
    Volkswagen Polo GTi
    2006 Volkswagen Polo GTi - Top Speed
    http://www.carenthusiast.com/roadtes...rticle&id=1776
    Mar 2006
    [9N-9N3]
    Exterior:
    Body kits
    http://www.vwwatercooled.org.au/newf...ad.php?t=11376
    Front Splitter
    http://www.vwwatercooled.org.au/newf...ead.php?t=4801
    Exterior Lighting:
    Polo 9N3 Head Light Bulb Changing Guide:
    http://www.vwwatercooled.org.au/newf...ad.php?t=10756
    Polo 9N3 Rear Tail Light Removal.
    http://www.vwwatercooled.org.au/newf...ad.php?t=10883
    9N3 Light Globes list
    http://www.vwwatercooled.org.au/newf...ead.php?t=9442
    HID Disscusion
    http://www.vwwatercooled.org.au/newf...ad.php?t=11941
    Interior:
    Trim Removal
    http://www.vwwatercooled.org.au/newf...ead.php?t=8102
    Polo Stereo Info
    http://www.vwwatercooled.org.au/newf...ead.php?t=5808
    http://www.vwwatercooled.org.au/newf...ead.php?t=2929
    Polo Tool Kit Reassembly
    http://www.vwwatercooled.org.au/newf...ead.php?t=6897
    Polo 9N Pollen Filter Clean / Change.
    http://www.vwwatercooled.org.au/newf...ad.php?t=10755
    Interior Lighting:
    Suspension :
    DIY - 9n3 Forge Strut Brace Instal
    http://www.vwwatercooled.org.au/newf...ead.php?t=8849
    How To Fit The Whiteline Rear Sway Bar
    http://www.vwwatercooled.org.au/newf...=rear+sway+bar
    Polo Suspension
    http://www.vwwatercooled.org.au/newf...ead.php?t=1396
    Brakes:
    Standered brake pad options:
    http://www.vwwatercooled.org.au/newf...22&postcount=6
    http://www.vwwatercooled.org.au/newf...aded#post44153
    R32 334mm upgrade
    http://www.vwwatercooled.org.au/newf...ad.php?t=6745&
    Audi S3/TT 312mm Brake Upgrade
    http://www.vwwatercooled.org.au/newf...ad.php?t=2648&
    DBA 312mm Rotors worth it or not
    http://www.vwwatercooled.org.au/newf...ead.php?t=7322
    Drivetrain :
    Power Steering fluid location.
    http://www.vwwatercooled.org.au/newf...ad.php?t=11075
    APR Dog Bone Mount
    http://www.vwwatercooled.org.au/newf...ead.php?t=9842
    LSD Options.
    http://www.vwwatercooled.org.au/newf...ad.php?t=12607
    Transmission :
    What's a good rpm to shift to save fuel?
    http://www.vwwatercooled.org.au/newf...ead.php?t=3063
    Have you had gearbox problems with your Polo GTI?
    http://www.vwwatercooled.org.au/newf...ead.php?t=8246
    Wheels and Tyres:
    Tyre Discution
    http://www.vwwatercooled.org.au/newf...ad.php?t=11047
    http://www.vwwatercooled.org.au/newf...ad.php?t=11939
    Removing Rear Wheel
    http://www.vwwatercooled.org.au/newf...ead.php?t=7486
    DIY Wheel Refurb
    http://www.vwwatercooled.org.au/newf...ead.php?t=8860
    Intake and Exhaust:
    Seat Air Intake Installation
    http://www.vwwatercooled.org.au/newf...ead.php?t=6160
    Seat Air intake test.
    http://www.vwwatercooled.org.au/newf...ht=seat+intake
    Forge TIP Discusion
    http://www.vwwatercooled.org.au/newf...ight=Forge+TIP
    What gains are to be made with an exhaust system?
    http://www.vwwatercooled.org.au/newf...highlight=pipe
    Engine:
    -1.8T
    Noise When First Opening The Car Door.
    http://www.vwwatercooled.org.au/newf...ad.php?t=20212
    Turbo Bolt Problem
    http://www.vwwatercooled.org.au/newf...ad.php?t=10059
    http://www.vwwatercooled.org.au/newf...ad.php?t=10584
    Polo GTI - Do you have to use 98 RON?
    http://www.vwwatercooled.org.au/newf...ead.php?t=3172
    Fuel Consumption ?
    http://www.vwwatercooled.org.au/newf...ead.php?t=2894
    Engine Oil ?
    http://www.vwwatercooled.org.au/newf...ead.php?t=2506
    Boost Gauge Wiring
    http://www.vwwatercooled.org.au/newf...ad.php?t=11273
    http://www.vwwatercooled.org.au/newf...ad.php?t=35780
    Adelaide hills, SA
    Exclamation
    It's time for clean up, we have too many stickies on the front page of this subforum. Any suggestion for some stickies to be moved as a shortcut into this thread? If not, I will just unstick some and move some in this thread next week.
    Jan 2009
    blankedy
    This one is really out of date, I'd recommend un-stickying this thread and the following:
    Polo THS intercooler install part number thread
    ***The official my polo arrives thread***
    They seem to be the least popular of the stickies, thanks for cleaning.
