Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 93
Thread: Polo Dyno Day Brisbane, Saturday August 25th
  1. #61
    Jan 2009
    blankedy
    Top link is the normal forge unit for our car.
    Thermally it does well, its the potential flow issue, which cripples the turbos peak performance, or so it's been shown on 1 particular unit.
    I've been thinking the Forge core has to few tubes, as it makes 2 passes. It's not much taller than a normal design, where as the Seat core is practically 2 small coolers stacked vertically.
    Sorry, I should take this to the other thread...
  2. #62
    Apr 2011
    The Forge on my car performed best/equal best in terms of thermal cooling/intake temps, but I'm expecting to see a bit of discrepancy between requested and actual boost as I was peaking at ~19 psi where others were hitting 21.5+ which I'd expect to attribute to the pressure drop over the cooler. The restrictive stock exhaust on my car would have to contribute, too, of course...
    '16 Octavia RS Wagon
    Past - '07 Polo GTI
    '08 RenaultSport Clio 197
  3. #63
    I desperately NEED an intercooler! From what I saw, everyones temps sat around 35-50 deg even under full power. My poor little factory SMIC was topping out at 88 degrees... Bit more power to unlock there methinks.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  4. #64
    Nov 2007
    Quote Originally Posted by VWindahouse View Post
    Hey mate, from a thermal aspect only I think the
    list went like this from best to worst;
    Forge
    Seat
    Apr
    EBay Apr style. Sorry can't remember whether Jason's or Sharkies were better.
    Stock side mount.
    Interesting though was the Forge and Seat were the only two that didn't suffer from heatsoak.
    1. Forge - Leitch - kept temp increases amazingly low through all 3 runs.
    2. Ebay - Sharkie - outperformed the SEAT by a few degrees consistently across all 3 runs.
    3. SEAT - VWIndahouse - performed better than the APR by a few degrees consistently across all 3 runs.
    4. APR - Eddy - worst of the brand names in increase in each run.
    5. Ebay - Jasn78 - at least it is better than stock
    6. Stock - Spraycanmansam & GotBoost? - it sucks
  5. #65
    Jan 2009
    blankedy
    What was the ambient temp on the day?
  6. #66
    Jul 2007
    Quote Originally Posted by Redliner View Post
    Great numbers there guys. It would be good to do this in Sydney.
    Lol good luck! I've been going to the syd dyno days since 07 and I've been the only polo at each one bar one dyno day at Hornsby..
    Great figures guys! Impressive numbers for stage 2/3
    did I mention I still miss my polo..
  7. #67
    Feb 2007
    Brisvegas
    You clearly can't even read your own figures
    VWIndahouse 156.319 348.637 26 45 34 52 30 50
    Sharkie 151.603 312.014 27 40 35 51 39 57
    For those that were not there I had 4 runs actually. The first looked as though I may have been leaning out so after the car sat running on the dyno for 5 minutes or so while we debated whether it was safe to continue we finally went again which should be the first run recorded here.
    So my 4th run showed temps for 30 start and 50 finish.
    As opposed to your 3rd run temps of 39 start and 57 finish.
    You may want to google the meaning of the words "outperformed" & "consistently". Looks to me like Heatsoak got the better of your ebay job on your third run, but I'm just going off your figures of course.
  8. #68
    Jan 2009
    blankedy
    I'm hoping to see the graphs to help understand.
    Lower intake temps may marry up with lower torque figures in some cases.
  9. #69
    Feb 2007
    Brisvegas
    Just want to say congrats to Eddy and thanks for making the trip up. Not so much for the dyno figures (although still King) but for your out of this world commitment to your blue girl. Those that saw those front strut tops and custom suspension set up for example will testify. So much thought, passion and commitment has gone into it and your track times confirm you know how to pilot it too. Good man!
  10. #70
    Nov 2007
    We actually spent some time coaxing the temps down for the last run on your car .... by the time we got to mine and eddy's we spent a lot less time trying to get the temps down for the next run ....
    So for your 3 runs, #1 19 degree increase, #2 18 degree increase, #3 20 degree increase from start of run to end
    My 3 runs #1 13 degrees, #2 16 degrees, #3 18 degrees increase from start of run to end
    Last time I checked 13,16 & 18 was consistently lower than 19, 18 & 20 thus no need to google if outperformed meant less or more ...... unless I'm wrong
