Here's Dave's and mine on the same graph.
Couldn't agree more, although that's what ppl usually quote![]()
Dave described it best when he mentioned how his car hit peak power relatively early and was able to hold it across the rev range. That's the difference you want to see when you add mods, rather than unusual peaks and spikes. That said, Sam's power curve looks pretty decent too..
EDIT - when I mentioned variation in base dyno figures, I meant generally, not those that attended the dyno day, for instance, my base was between 116-120.
FOR SALE
"VW GTI" QLD Prestige Plate
Remarkable similarities, Sam. I'll have to get a zorst now ...
Dave
Yeah, the gains are pretty much all through the rev range, almost the same the whole time except at about 4000-4500rpm but then it picks back up again.
FOR SALE
Sam, notice how your peak begins to drop off around 5300rpm, ..that's pretty common, as boost begins to cut-off. A high-flow muffler would give you more slighty more power, and would hold power longer, bc when the exhaust is running at those speeds, the stock muffler will begin to choke flow. That's what my testing confirmed as well. How this translates on the road (I mean track) ...with the stock muffler, your car will slow down at 160kmh, with a high-flow, it will pull strong to 200kmh.
FOR SALE
FOR SALE
