Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 96
Thread: Polo Dyno Day - 9th August!!
  1. #61
    Jun 2007
    Quote Originally Posted by tosspot View Post
    Peak power means little if it's a sharp peak.
    Couldn't agree more, although that's what ppl usually quote
    Dave described it best when he mentioned how his car hit peak power relatively early and was able to hold it across the rev range. That's the difference you want to see when you add mods, rather than unusual peaks and spikes. That said, Sam's power curve looks pretty decent too..
    EDIT - when I mentioned variation in base dyno figures, I meant generally, not those that attended the dyno day, for instance, my base was between 116-120.
  2. #62
    Jan 2008
    Here's Dave's and mine on the same graph.
  3. #63
    Mar 2007
    Remarkable similarities, Sam. I'll have to get a zorst now ...
    Dave
  4. #64
    Jan 2008
    Yeah, the gains are pretty much all through the rev range, almost the same the whole time except at about 4000-4500rpm but then it picks back up again.
  5. #65
    Jun 2007
    Sam, notice how your peak begins to drop off around 5300rpm, ..that's pretty common, as boost begins to cut-off. A high-flow muffler would give you more slighty more power, and would hold power longer, bc when the exhaust is running at those speeds, the stock muffler will begin to choke flow. That's what my testing confirmed as well. How this translates on the road (I mean track ) ...with the stock muffler, your car will slow down at 160kmh, with a high-flow, it will pull strong to 200kmh.
  6. #66
    Mar 2007
    Quote Originally Posted by GT3 View Post
    Quite right Neil, ... I saw Eddy's and it doesn't dip at the 5,500 mark.
    Dave
  7. #67
    Jan 2008
    Quote Originally Posted by DaveMack View Post
    Dave
    Eddy's actually seems to dip more at 5500rpm but then it goes up again and drops again.
    Blue is 'stage 1' and red is 'stage 2'
  8. #68
    Mar 2007
    Damn ... so it does. Whose was I thinking of then?
    Dave
  9. #69
    Jan 2008
    Dave
    Maybe backyard bandit (Jason).
    But his dumped fuel in like it was a Veyron - without the other benefits
  10. #70
    Jun 2007
    I wouldn't read too much into that dip, Polo GTIs are notorious for doing that on dynos. His car still manages to maintain peak power at 6000rpm...
