Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 100
Thread: Polo Dogbone Mount.
  1. #21
    Jun 2007
    Quote Originally Posted by Timbo View Post
    So I'm keen to see mine on a dyno
    Hop to it Tim - best way to find out
  2. #22
    Oct 2006
    Should this be done after or before LSD?
  3. #23
    Nov 2006
    Quote Originally Posted by Flaps View Post
    If you mean as in before considering an LSD as a mod, the answer is yes; if you mean 'I am getting an LSD fitted', then get this at the same time.
    So the answer is yes -- this is probably a must-have if you are doing any serious track work
  4. #24
    May 2007
    I'm intrested to know...
    I have the issue, where on occasion, my pog will grind / crunch going 2nd to 3rd when shifting fast, at high revs. Almost as if the clutch doesn't fully disengage... its not a HUGE issue, its always shifts, just makes a crunch going in, i'd say its happened 20 times in the last 15,000 k's. It doesn't sound to good, and i can imagine it isn't too good for the gear box.
    If anyone who has got this mount has had this problem in the past, and knows if this fixes, it... i'd be very intrested.
  5. #25
    Alfred Cove, WA
    Quote Originally Posted by pomme View Post
    This would be good to know. I have the same problem but VW just seem to replace the box if it happens.
  6. #26
    Sep 2006
    Brisvegas
    well i had the problem grinding between 1st and 2nd at high revs, so Guy kindly offered me one of the prototypes and it didnt fix it. Although from then i had bugged him for the mount every week ask alex. lol
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  7. #27
    Sep 2006
    Brisvegas
    As to the observed 'improved' gear change phenomenon -- obviously due to some mass to energy transformation in the space-time continuum -- I'm buggered if I can understand how there could be, nor can I feel, any improvement in the Pog's cable gearshift mechanism!
    Mate if you cant feel the difference i think you should drive one with standard mount again. But then again you could be the only one with a perfect gearbox.
    Have a Look
    CUSTOM CODE
    Phase 2
  8. #28
    Dec 2006
    Gold Coast
    Im reallly tempted to get one soon. Crunching first to second is starting to annoy me tho.
  9. #29
    May 2007
    The crunching happens rarely for me, and 2nd to 3rd, i can't be arsed going through the hassle of replacing...
  10. #30
    Jun 2007
    I'm a bit surprised by how many pog dudes are coping crunches b/n gears I've never encountered it, and if I did I wouldn't tolerate it for long. It may be bc I've got the vibe for gear changes and I'm down with the "mass to energy transformation in the space-time continuum"
