Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 100
Thread: Polo Dogbone Mount.
  1. #31
    Dec 2006
    Gold Coast
    Quote Originally Posted by GT3 View Post
    I'm a bit surprised by how many pog dudes are coping crunches b/n gears I've never encountered it, and if I did I wouldn't tolerate it for long. It may be bc I've got the vibe for gear changes and I'm down with the "mass to energy transformation in the space-time continuum"
    I find that it normally happens to me going up a slight hill. Never on the flat...
  2. #32
    Nov 2006
    To explain my oh so subtle point: the Polo gear change linkage is a cable system, not a directly connected linkage. Therefore, reducing engine mount movement with a stiffer dog bone mount insert will not effect the gearchange 'feel'. This cable gearchange mechanism is the reason why the Pog doesn't take to flat shifting very well -- there's too much give to make the necessary quick changes.
    If you are suffering gearchange issues -- grinds, graunches or whatever -- and you are changing gears properly, then I'd suggest a trip to the dealer is in order, especially as others have reported problems resulting in g/b replacements.
  3. #33
    Sep 2006
    Brisvegas
    Well the proof is in the pudding (both eddy myself and GT3 can tell the difference) and the fact that Guy agrees as we chatted about it when i went back to give back the test dogbone mount kinda tells me that we arent feeling something that isnt there.
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  4. #34
    Jun 2007
    Bumped into Ezzy yesterday and he too confirmed a big improvement. If you go back to my original comments, I actually said that I noticed an improvement in gear 'selections' not 'changes'. This was particularly noticable when stationary, ie selecting reverse or 1st gear. The box feels more tighter, more solid to use. Not sure how the new mount induces that but it somehow does. I can't comment beyond that, ie how it improves the transfer of power, and I'm not sure whether it will limit or reduce engine movement either.
  5. #35
    Nov 2006
    I had the crunch between 2nd and 3rd and it went away after a little time.
    I'm just thinking if this will help out on the track???
    aus liebe zum automobil
  6. #36
    Jun 2007
    Brunswick, Victoria
    Thumbs down Crunching
    In regards to the crunching my Polo crunches EVERYTIME when changing from 1st to 2nd above 2500rpm.
    I had the problem looked at by Volkswagen. They wont be replacing the gearbox but they are rebuilding certain parts. The parts have arrived from Germany and the car is booked in for the 21st to have it all done.
    Fingers crossed it fixes the problem. I will provide an update once it is done
    Current - MY12 MK6 GTI, CW, Detriots, dark tint, APR Stage 1, blacked out grille, LED tails, Euro plates, suspension "tweaked", VCDS tweaks
    "The Ex" Black MY08 POLO GTI - APR,Coilovers,5% tint,stubby antenna, rear sway bar
  7. #37
    Alfred Cove, WA
    Quote Originally Posted by Koz View Post
    .....The parts have arrived from Germany and the car is booked in for the 21st to have it all done.
    Make a point about them cleaning out all the metal filings off the magnetic filter in your box too because there will be a lot.
  8. #38
    Jun 2007
    Brunswick, Victoria
    Ok sweet - Not sure what that means but ill definately tell them too.
  9. #39
    Alfred Cove, WA
    Most gearboxes have a magnet that sits in the oil somewhere, so when you shave metal off your gears the little bits of metal stick to the magnet rather than crunching through the teeth of the gears.
  10. #40
    Jun 2007
    interesting and so tempted mod. if not only from my oh-so-big-spending-audio-installation......
    i got a question regarding the gearbox which i hope you guys can help, as you are more tech minded then I..
    I used to get the crunching from 2nd to 3rd, but it kinda gone away now, or that i just havn't shifted at higher revs, and faster (fuel cost! =(...) anway, lately, i have been finding while changing gear, the gear would get stuck, or hard to get into the slot, or it would get stuck halfway, and sometimes crunches the gear...
    Is this a major problem? what can causes it??
