Results 1 to 5 of 5
Thread: Polo Bump Strips
    May 2011
    CAMPBELLTOWN
    Polo Bump Strips
    Just a quick one.
    Bump strips on the polo's side. how are these removed?
    Front bar were clips. not sure about the doors.
    any help would be great
    Matty.
    GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
    Feb 2007
    Brisvegas
    Hey Matty, I tried this and lucky for me stated to take them off in the "right" area explanation to follow
    I started by heating up the end of the bump strip on the body of the car pointing towards the front (not the door) then it started to peel it back slowly only to find about an inch along there was a guide hole in the bodywork. Lucky the glue hadn't dried so pushed it back on and there it stayed.
    I can only guess there is two guide holes for those strips to keep them level. Can only assume the same for the doors. Can't imagine how much a body shop would charge to fill and paint over all the holes so gave up completely on the idea. But if you're super keen to get rid of all yours I did find out there is a 9n3 Polo made in South Africa called the Vivo which has a smooth rear bumper (no strip) and a Polo 6R front that would also fit and save a heap of labor.
    Cheers.
    May 2011
    CAMPBELLTOWN
    Hey buddy. Cheers for that. my plan is to take them off as im wrapping the car at the moment and want the best result. so its a glue not a Double sided tape?
    Matty
    Feb 2007
    Brisvegas
    Ah yes forgot you were wrapping it It's just the glue from the double sided tape I was talking about.
    Looking forward to seeing the end result Matt!
    Dec 2012
    Sutherland Shire, Sydney
    I've wrapped my dash and roof rack rails (Skoda Octavia)
    Planning to do the door bump strips and door handles next - a little more challenging
    My bump strips are stuck to the doors with double sided tape - planning to wrap them in place (careful with the exacto knife!)
