Originally Posted by
sambb
Hmm thats a while ago. mechanically stg2 Ko3s (3 inch dump to 2.5 rear, SEAT IC, custom tuned as 7psi wastegate spring and bigger injectors), wavetrac diff, A050 semis (215 medium fronts, 195 soft rears), lots of work getting hillclimb cold tyre handling right eg MCA purple coilovers 7kg front springs, 8kg rear springs, whiteline rear bar on stiff, stock front bar, bit of rear toe out 2mm total, bit of front toe out 2mm total, stock front ride height, as low as possible rear ride height, front adjustable tops set to max pos caster and some moderate neg camber. + full send! Down the bottom you need to be jumping the kerbs. Use the white post as your turn in markers for the chicane because you cant see the chicane over the crest after you've first come out onto the main track. That way you have the car moving the right way before you can even see the chicane. After that its late turn in everywhere so you can be back to full throttle the moment you have the car rotated. Really important to do that on the bottom corner before the run up the hill because if you get that wrong you'll be paying for it with a lack of horsepower the whole way up.
Thats the only time I've won a state round of the hillclimbs (road reg 2WD over 2.5L class) so I was elated after that. Thats a pretty darty setup though that needed my full attention at faster tracks. For any non hillclimb stuff like Wakefield etc I had mediums for the rear. I'd love to go back there again now that I have much more power and its even more dialled in.
