the rear control arm bush is rubbish, get the solid ones from Jmac / Gav if they still have them (or ~30 from OS if I remember correctly).
Hi all,
I was buying parts to service my Polo, and found it rather difficult to find the required part numbers.
I made a quick list of part numbers that might be useful to others. There is also a lot of good information on the Meyle and Febi Bilstein websites.
There may be mistakes, so please double check.
Suspension
Lower Control Arm Front Bush (34mm OD, 54mm H, 12mm ID) :
6Q0 407 182A
6Q0 407 151L
Superpro SPF3311K
Meyle: 100 407 0094
Lower Control Arm Rear Bush (65mm OD, 50mm H, 19mm ID)
1K0 199 231
1K0 199 232
6Q0 407 183
SEAT Replacement - 1K0 199 231/2G
SuperPro - SPF3273K (w/ camber offset), SPF3271K (no offset)
Lower Engine Mount ("Dogbone")
Powerflex PFF85-620 (70 Shore, for petrol engines)
Powerflex PFF85-620P (80 Shore, for track)
Powerflex PFF85-620R (65 Shore, for engines)
Superpro SPF2907-70K (70 Shore)
Superpro SPF2907-80K (80 Shore)
Front ball joint LEFT
6Q0 407 365 A
6Q0 407 365 D
6Q0 407 365 F
6Q0 407 365 M
Front ball joint RIGHT
6Q0 407 366 A
6Q0 407 366 D
6Q0 407 366 F
6Q0 407 366 M
Filters
Activated carbon cabin filter (Width 216 mm, Height 30 mm, Length 246 mm)
6Q0 819 653
6Q0 819 653 B
Comline: EKF122A
Particulate Filter (Width 216 mm, Height 32 mm, Length 252 mm)
6Q0 820 367
6Q0 820 367 B
Comline: EKF122
Fuel Filter Aluminium / Steel
6X0 201 511
6N0 201 511 B
Engine
Seat Curpa PD160 Intake:
6LL 129 621 - Trumpet
6LL 129 618 - Pipe
Please reply to this thread if you have useful references to share with others.
Cheers.
There has been an update of the LCA rear bush -- it's slightly less crap than it used to be (although the solid is still better, of course)
