This should free the globe.
Place new globe in and do steps in revers order.
Low Beam:
Twist the plastic holder Anti-clockwise and the 2 metal prongs will dislodge the globe.
Polo 9N3 Head Light Bulb Changing Guide:
Due to lack of space on the passenger side of the car I have taken some pics of a head light unit out of the car.
NOTE: Do not touch the glass of the Globe with your fingers this will shorten the life of the Globe.
Step one:
Remove the plastic covers on the rear of the lights.
Step Two:
High Beam
Unplug the single wire connecting the globe.
Press down on the wire clip holding the globe in place.
Low Beam:
Pull the Globe out of the Holder and replace, Revers steps to secure again.
Indicators:
Twist the plastic paddle Clock wise this will undo the holder then simple pull out.
Park Lights:
You have to have very small hands to get to them:
The easiest way I have found is to gentle pull on the wires that they connect too.
Well done...are there any special/extra work needed to install brighter globes.
Maris
Rob, Great guide. Thank you
I would say yes to install a higher watt globe but u can go for a whiter light which gives the effect of brighter.
Philips make a blue vision, dimond vision and a crystal vison which work really well in the polo.
They are not cheap tho.
To change to a higher watt i think u would need to check things like fuses and gauge of wire to make sure the loom can hadle the extra current draw.
I would suggest taking out the whole headlight assembly to change the globes if your household runs a swear jar.
It is the most irritating task to install them with the headlight in place.
I'll be sure to give this a shot sometime after mine arrives - hopefully with some help from smaller hands 'cause I won't be disassembling the car
