Polo 9N - 00778 Steering angle sensor no comms
Hello and ....help please,
I have just purchased a 2008 Polo tdi manual from auction for one of our kids. Runs, drives, stops - everything seems fine, BUT the orange steering light is on.
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F6D1EFEED041DEB62-5122
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
I am confused as to exactly where the sensor is. Some reading tells me the G85 is behind the steering wheel, I have replaced the clock spring (which several videos claimed was the sensor too) with a used unit to find no change. This lead me to dismantle the clock spring to find it is just a clock spring - there's no sensor in there.
Next I have identified the "Steering Assist" module as being part of the power steer pump mounted below the LH headlight. Centre plug is power feed, Plug #2 is data (unplug it and the module disappears from network), Plug #3 is a 3 pin plug that goes to the steering rack. I assume this is my steering angle sensor? Testing resistance at plug#3 on the wire going to the rack shows open circuit.
Q#1: Is this sensor on the rack the G85 - or is it G250?
Another interesting thing I've noticed: The car has had a LH front accident which I assume is very recent. I notice when I removed the LH it has the fresh markings of a parts breaker AND I notice the power steer pump has a manufacture date of ... 06.09.2011. Given the car has a compliance date (off the ship and inspected in Australia) of early 2008, it appears obvious that someone has replaced the power steer pump with a used unit out of a 2011 or 12 car.
Is it possible I have a Module with incorrect coding?
Or is the G85 on the rack and try replacing it?
Octavia vRS TDi DSG MY10 - RD Technik tuned
Polo 9N3 1.9TDi
