Body Control Module(BCM) is the first spot to check.
Please show us your coding block. The "Not Installed" is an indicator the BCM is not configured properly.
Matching existing part number to the vehicle's VIN. Rego/VIN; we can check for you.
If it's been replaced. It may be the wrong part, following wrong pinout.
And here you want to be sure there aren't any wires missing.
P0050349020-Basic_equipment__From_November_2001.pdf - Google Drive
Search the entire document; mostly be from pages 450 and up will be relevant.
I haven't worked on the central locking on a 5 door; but I will assume it is similar to a 3 door's front; where the door module is located with the window regulator.
Do the windows go up/down? or are they manual? Manual windows; the wiring goes directly to the BCM(I believe).
