There's something not 100% if your 003s aren't grippy.
I have never had the back come round on me in the Squib. Whiteline rear bar set to hard. Even in the wet it's planted. MCA coilovers
Yours looks pretty tall, is it on std suspension? That's probably it.
I have some Powerflex dogbone inserts for $75. The purple track version. Most folk complain about the vibration but I think they mostly need to harden up
My brake pedal sinks a bit, it's much better after using VCDS to cycle the ABS valves. I'll be doing a fluid change tomorrow afternoon before Happy Laps.
Have you had a tune? Couldn't see that mentioned.
Quote Originally Posted by Euromy View Post
Thanks louis,
Definitely have noticed the 'tdi' polo down the road with the yellow gti (Pirelli edition?).
How exactly do you do a linkage reset? and I'm thinking a dog bone mount might also be causing it.
And that's good to hear, was wondering if t2s were worth the extra bit. Was initially planning to do the tt brake upgrade but funds and time are the issue at the moment.
Also, rear tends to kick out without using the throttle to persuade it. Though can induce lift off at times.
