There's a limitation in that you can't get the 3 inch plastic MAF to fit into the std lid. The aluminium ones that I tend to use may work though.
Yeah me and Ryan (BFLAT) both run the Jabba Sport Cone in a Box.
2019 132TSI Tiguan
2011 Audi S4 Wagon
1988 MK1 Caddy
2006 Polo GTI
Awesome. Can't wait to hear some results.
2007 Golf MKV 2.0 TDI DSG | CustomCode Phase1 ECU + DSG | aFe Stage 2 | SprintBooster | KW Variant 3 | 19" Breyton GTS-R | GTI Side Skirts | GTI Front Bar | GTI Shifter
Was the piping a tight fit? Would there be any chance of it falling apart or hitting the maf sensor? Cant wait for results![]()
Pod in a box, its called a BMC CDA![]()
MODS- TOO MANY
No, it's all held together with jubilee clips and there's flow straighteners either side of the MAF. The element is quite safe. You have to modify the lid a bit but you can't see that when it's all together.
BMC CDA is good if you want to fit a small battery, otherwise I reckon this ticks a lot of boxes.
We'll test this sucker (haha, get it?) next Friday![]()
Mods >1
im currently going to try messing around with mine soon. i have intentions of laser cutting alloy or stainless (bling factor) and using a 90bend. depending how bit i make the new lid i should be able to run larger filters. plus if i run stainless i can etch it cool designs lol.
2006 Polo GTI | APR Stage1 | PD160 | K&N Panel filter | Forge TIP | Forge DV | Forge IC Piping | Milltek TBE |
| Forge Front/Rear Strut Braces | SEAT RCA Bushes|
