Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Pocong Build Thread
    Kuala Lumpur
    Pocong Build Thread
    Hi Guys,
    I just would like to share with you my humble Polo GTI from Kuala Lumpur, Malaysia. Mildly modified and as it comes to fifth year anniversary, the car is currently at workshop undergoing turbo transplant with necessary kits to push the power figures slightly upwards.
    Next upgrade would be LSD, stg2 clutch and beefier front and rear brakes. Hopefully..
    Engine
    Stock VAG BJX 1.8T 20V
    FrankenTurbo F21T turbo (new)
    FrankenTurbo exhaust manifold (new)
    Mitsubishi Lancer Evo3 intercooler (500mmx300mmx65mm) with all new custom piping
    VF Engineering Race Bypass Valve (relocated)
    Wahle 80deg thermostat
    3” MAF (new)
    K&N open-pod filter with heat shield
    Exhaust System
    Custom 2.5” catless downpipe
    Custom 2.5” exhaust piping
    Blitz Spec Nur muffler with custom silencer
    Electronics/Engine Management
    Stock Bosch Motronic ME 7.5
    Genesis 415cc fuel injectors (new)
    VW 4bar fuel regulator (Stock 3bar fuel regulator can be refitted if necessary)
    Unitronic Stg 1+ Reflashed
    NGK BKR7E (0.028 gap) copper plugs
    Transmission & Drivetrains
    VAG 02R 5-speed manual
    ECS Stg 1 Clutch Kit
    ECS Single-mass 14lbs flywheel
    Suspension
    H&R Monotube Coilovers
    Seat Ibiza solid-rubber front bushings
    Ford Mondeo’s ARB links
    ECS PU rear axle bushing kit
    Brakes
    Front: VW 312mm x 25mm vented rotors
    Front: Single pot ATE 54mm calipers
    Front: EBC Red Stuff pads
    Rear: VW 232mm x 9mm solid slotted rotors
    Rear: Single pot Lucas 38mm calipers
    Rear: EBC Red Stuff pads
    ECS Steel braided lines
    Wheels & Tyres
    Wedsport SA70 17x7.5 rims
    Federal 595 RSR 215/45/17 tyres
    Dyno tests:
    178.57whp/253.67nm on DynoJet
    174.6whp/288.7nm on DynoDynamics (10/12/2010)
    216.40whp/326.97nm on DynoJet (16/07/2011)
    205.13whp/304.5nm on DynoJet (19/08/2011)
    Kuala Lumpur
    The Car
    Sunday Drive with Gojiras
    Engine Bay
    Idea Behind Custom FMIC
    Evo3 Intercooler
    Engine Bay (Close-up)
    Discreet Front Mount
    With H&R Coilovers
    Suspension Setup
    Wedsport SA70 Replica (Resprayed)
    Custom 2.5” Piping
    Blitz Spec Nur
    Genesis 415cc Injectors
    FrankenTurbo F21T
    Compressor Map
    Comparison Between K03S with F21T
    Jun 2009
    Looks great!
    Might be worth looking into a lightweight battery or a relocation to the boot.
    Kuala Lumpur
    Thanks, I'm also looking into possibilities of relocating the battery to the boot. That allows me to have bigger and better induction system
    Wow, stunning build!
    Thanks for sharing.
    Aug 2012
    Sydney NSW
    Looks good.
    Your engine bay is nice and neat.
    The wheels suit it. Are they a standard fit or did you have them redrilled?
    Quote Originally Posted by firdausasri View Post
    No need to mess about like that, you can fit all manner of smaller batteries in the front. Check my thread and the little red devils for starters.
    May 2009
    Pocong Build Thread
    Good to see a fellow malaysian here.
    Polo looks very tidy. Keep it up.
    ============================> http://www.facebook.com/EuroCarModsAus <============================
    Oct 2010
    Melbourne, VIC
    my humble Polo GTI .... Mildly modified
    I beg to differ
    Nice car, though I'm surprised it doesn't bottom on the roads over there
    Resident grumpy old fart
    Feb 2007
    Brisvegas
    Amazing stuff mate! Especially love the Intercooler set up.
    But I don't think those fuel injectors are meant for the polo. Could be wrong but I think you'll find the spray pattern all wrong plus I would be surprised if the fit in the intake manifolds injector seats. You need the EV14 style injector I'm pretty sure but check with your installer.
    Keep up the great work!
