I was just reading a quote from an NGK FAQ where the advice was that in forced induction engines, you should reduce your plug gap by 0.1016mm for every additional 50HP you have added above stock.
The 1.8T comes with a recommendation for 28 thou (0.7112mm) gaps. Using my car as an example it is flowing 188-190g/s through the standard MAF which equates to roughly 230HP. The car is 150hp standard meaning I've added an additional 80hp.
So by doing a ratio that additional 80hp means I should be shrinking the plug gap by 0.16256mm. That would reduce my plug gap from 28 thou (0.7112mm) down to 0.54864mm which is still evn a bit less than 22 thou.
I had actually already brought mine down from 28 to 25 thou after doing a bit of reading that suggested slightly smaller gaps work better with auxillary water injection and to be honest the car did feel snappier and less prone to bogging.
I've always been happy to be a guinea pig on left of field things but 22 thou sounds awfully small. Has anyone else out there with the more mental engines experimented to this extent with shrunk plug gaps and have any feedback.
thanks
sam
