On the stage 2 topic, does APR do stage 2 and if so, what mods are needed?
Depends on your long term goals. If I wanted short term bang for buck
PD160 + flap mod
CC phase 1
Forge 008
SAI delete
Superpro LCA bushes
Vibratechnics mounts, or just the dogbone mount/bush if budget is tight
Whiteline front sway bar
KW V1 or other suitable coilovers
Good set of tyres
About 4k ish at a guess and you'd have a car with a bit of go, nice stance and good handling.
I went down the phase 2 path and it adds a few k onto it by the time you've done the exhaust and FMIC.
08 9n3 Polo GTI
Mods: heaps
Rgvlee, you mean rear sway bar?
APR bypasses the exhaust sensor, I believe the tune is the same. The mods do the work, not all mods require coding.
Question? The tune will work with the added efficiency, but like doing the PD160 does not require a retune and gives great results, similar with the zorst.
I could be wrong, no one has chimed in to tell me so (yet).
Technically all mods would work best with retuning, but since we all use generic maps it won't really matter, unless you get a tunable ECU with a custom tune
Have done some research and there's isn't much available locally stage one Apr is 1450 seems a bit excessive I'm still waiting on hearing back from another place too.
Custom code, half that price.
If you don't want to ship your ecu do the flashwire.
08 9n3 Polo GTI
Mods: heaps
