Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Please VWwatercooled pimp my ride
    Nov 2012
    WA
    Depends on your long term goals. If I wanted short term bang for buck
    PD160 + flap mod
    CC phase 1
    Forge 008
    SAI delete
    Superpro LCA bushes
    Vibratechnics mounts, or just the dogbone mount/bush if budget is tight
    Whiteline front sway bar
    KW V1 or other suitable coilovers
    Good set of tyres
    About 4k ish at a guess and you'd have a car with a bit of go, nice stance and good handling.
    I went down the phase 2 path and it adds a few k onto it by the time you've done the exhaust and FMIC.
    08 9n3 Polo GTI
    Mods: heaps
    Sep 2014
    On the stage 2 topic, does APR do stage 2 and if so, what mods are needed?
    Apr 2014
    Perth
    Rgvlee, you mean rear sway bar?
    Jan 2009
    blankedy
    APR bypasses the exhaust sensor, I believe the tune is the same. The mods do the work, not all mods require coding.
    Sep 2014
    W-what
    Jan 2009
    blankedy
    Question? The tune will work with the added efficiency, but like doing the PD160 does not require a retune and gives great results, similar with the zorst.
    I could be wrong, no one has chimed in to tell me so (yet).
    Sep 2014
    Technically all mods would work best with retuning, but since we all use generic maps it won't really matter, unless you get a tunable ECU with a custom tune
    Have done some research and there's isn't much available locally stage one Apr is 1450 seems a bit excessive I'm still waiting on hearing back from another place too.
    Nov 2012
    WA
    Custom code, half that price.
    If you don't want to ship your ecu do the flashwire.
    08 9n3 Polo GTI
    Mods: heaps
    Adelaide hills, SA
    I can't give it to you for free to pimp your ride, but you can have the tune for $690 from me (subject to my mechanical inspection, which is free).
    I had a few tunes that I've decided to let go for less, but they're all gone now. However the Christmas special $880 remains till the end of January.
