I have RE003s on my car, very nice to drive on, but I went up to 55 profile - the speedo is spot on accurate, but I reckon they're too heavy...
I had these spacers made - they go between the stub axle and the rear beam so are permanently installed rather than spacers that go between the wheel and hub...
I'll take one for you - I'll see if I can take it from the same angle as yours. I made the spacers in 3/8" and 1/2" so it pushes the wheel out that far. I have the 3/8" version fitted. The difference between spacers and ordinary wheel spacers isn't huge, but theoretically these put less load on the wheel bearings, they're lighter and definitely cheaper
I did it to make the track wider for handling, but it does look cool - the difference really stood out when I dropped the car on the ground after putting them in.
I have a set of lowering springs (~30mm drop I think?) that are surplus. Sam sold them to me for cheap, happy to pass them on
Your a champion. Brisbane guys look after each other!![]()
Whiteline Rear Sway bar purchased as well as a Front Control Arm Lower-Inner Rear Anti Lift Bush Kit - looking forward to them arriving for my first Polo project works![]()
Front stabilizer bar is pig to install!
