Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Phillip's little Red (Marco)
  1. #21
    Sep 2018
    Brisbane (Drewvale), QLD, Australia
    Quote Originally Posted by Polo GTEye N9 View Post
    Front stabilizer bar is pig to install!
    I haven't even looked at the front yet, just going to focus on the rear and the lower control arm stuff for now.....
    *he says as he Googles videos on front seat bar installation and parts pricing Phillip's little Red (Marco)*
    Sent from my SM-G930F using Tapatalk
  2. #22
    Jan 2009
    Don't bother with the front bar unless you're doing a complete upgrade. Even than, personally wouldn't suggest doing it. My car has had the front sway bar replaced/upsized, but frankly if it wasn't such a PITA of a job, I'd swap back to stock. Now that this car is not being used for daily duties, I might just do that at some point.
    To get the most from the upsized front bar means doing custom rear springs to increase the rear spring rate. Even with rear bar set to hard, some more rotation would be beneficial on track. For street driving, absolutely not worth it IMO. Doing the front bar also limits front wheel travel, which also isn't ideal. I've had more fun driving (and perceived levels of grip) with the front bar disconnected.
    Daily: 2010 VW Jetta Highline
  3. #23
    Oct 2017
    Wodonga, Vic
    Sam just went back to stock with his front bar
  4. #24
    Sep 2018
    I think that's what I love about forums like this. Finding out this type of info can often be trial and error. I'm glad that someone else has already trialled and deemed it an error so I don't have to Phillip's little Red (Marco)Phillip's little Red (Marco)
  5. #25
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by BrisPiripi View Post
    Oooooooh - I like it. A bit lower than mine too.
    I'll have to add that to my growing list of projects
    How much you after for the lowering springs?
    the front is actually not lower than standard - it's 100% stock but I have taller profile tyres so less guard clearance. The back is lower than standard but I have no idea how much, they're cut down springs from the front of a Honda
  6. #26
    Mar 2015
    Mine was easy to install. I just paid the mechanic to do it while they fitted the Eibach springs and B8 Bilstein's.
    I have the H&R front and rear sway bar kit fitted and with that spring/shock combo, the handling is batsh*t crazy.
    All up with including fitting a front LCA poly bush I paid a bit under $600 labour for the whole job.
  7. #27
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by MattSA9N3 View Post
    I hate paying labour for things I can do myself, but that's actually quite reasonable for the amount of work they did...
  8. #28
    Mar 2015
    Quote Originally Posted by simon k View Post
    I don't get my ambitions mixed up with my ability .
    Plus living in a unit with no garage or tools doesn't help. I just drop the car off, use their loan car all day and pick it up after work with the new bits in it.
  9. #29
    nsw
    Paying 600 bucks in labour for all that is very cheap. lucky to have found that. Yeah I just put the front bar back to stock and agree that a front bar for a street car is unecessary especially considering the extent to which it hurts ride quality. Different story compared to a rear bar though which is an absolute must do/step 1/ starting point.
  10. #30
    Sep 2018
    Very cheap indeed.
    Does anyone have any suggestions where to buy the following?
    TIP
    Downpipe/exhaust (in Brisbane)
    Intercooler and piping
    Stage 1 tune
    I've had a look through the forum and unfortunately, everything looks like it is super dated and potentially no longer applicable
