Originally Posted by
Bullet Fast
Gav knows already, but for what it's worth, my 9n3 Gti is on work stands in the back of my shop getting the worx treatment. There's a huge pile of internationally mailed parts sitting next the car. Quick summary: Frankenturbo hybrid, MAF, TIP, injectors, fuel pump intercooler intake etc etc. theres a couple of small things that will get done while the engine is so accessible, ill make some bits and pieces here and there...
Interestingly, the turbo bolts were finger tight when I pulled the snail. The gasket looked like a burnt taco. Manifold has a crack across a web towards at the turbo flange radiating out to a bolt hole. Hot side turbo housing has a matching crack between waste gate and turbine port. Hmmm, Really should think about idling turbos before shut down hey? There doesn't appear to be any end float of the shaft, but who cares now anyway?
I will have to put the Frankenturbo manifold in for the moment, although honestly I'm not impressed. You would think Frankenturbo could be a little choosier with their QA/QC, it's just an ugly casting. I ran the laser scanner over the manifolds to start some reverse engineering on the design but honestly I can't see it a viable project... It's such a tight gap and difficult shape to work with. It would be cool though, I might ring a foundry and ask for a laugh.
Car will get an exhaust but probably only a DP and Cat.
So all I have left to decide on is an oil type... Any suggestions? I'm a fan of: buy the most expensive oil you can afford to change every six months.
