Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Petes Polo goes big
    Nov 2012
    Petes Polo goes big
    Gav knows already, but for what it's worth, my 9n3 Gti is on work stands in the back of my shop getting the worx treatment. There's a huge pile of internationally mailed parts sitting next the car. Quick summary: Frankenturbo hybrid, MAF, TIP, injectors, fuel pump intercooler intake etc etc. theres a couple of small things that will get done while the engine is so accessible, ill make some bits and pieces here and there...
    Interestingly, the turbo bolts were finger tight when I pulled the snail. The gasket looked like a burnt taco. Manifold has a crack across a web towards at the turbo flange radiating out to a bolt hole. Hot side turbo housing has a matching crack between waste gate and turbine port. Hmmm, Really should think about idling turbos before shut down hey? There doesn't appear to be any end float of the shaft, but who cares now anyway?
    I will have to put the Frankenturbo manifold in for the moment, although honestly I'm not impressed. You would think Frankenturbo could be a little choosier with their QA/QC, it's just an ugly casting. I ran the laser scanner over the manifolds to start some reverse engineering on the design but honestly I can't see it a viable project... It's such a tight gap and difficult shape to work with. It would be cool though, I might ring a foundry and ask for a laugh.
    Car will get an exhaust but probably only a DP and Cat.
    So all I have left to decide on is an oil type... Any suggestions? I'm a fan of: buy the most expensive oil you can afford to change every six months.
    Quote Originally Posted by Bullet Fast View Post
    Don't forget to take pictures.
    Yes please, take lots of pictures and post them progressively.
    Good idea Gav......
    Kuala Lumpur
    Glad to hear another Polo GTI with FrankenTurbo. Keep us updated ya
    Aug 2012
    Sydney NSW
    Check out the frankenturbo actuator thread on VWVortex.
    It may be worth changing the actuator before the install.
    Are you going with the F23 or the F21?
    Goodluck with the build.
    Nov 2012
    I'm usually to busy swearing and busting knuckles for photos. I'm good with screen shots though.
    Its an F21t. Good tip on the actuator. Ill have a look tomorrow. There's no reason to think mine's any different. There might need to be a transfer old to new. Gav have you seen this on yours? I've been thinking a MBC might not be a bad idea anyway...
    What do you want to see? It looks like a regular polo with a seat cooler and green injectors! Ill take some rev engineering screen shots, cause that's pretty badass.
    Feb 2007
    Brisvegas
    Nice work Pete! Great upgrade there fella, but you may be better off using the ko3s actuator with the f21. You only need to see 6 psi with the F21 and that's what the BW actuator should be at from factory give or take a couple of quarter turns.
    Jan 2009
    blankedy
    Assuming Stage 3 CC?
    Good to see another BT/HT going on, went from a drought to a flood.
    Nov 2012
    Quote Originally Posted by VWindahouse View Post
    I read throu all the garbage on vwvortex. TBH, business ethics aside, there's really not a lot going there that actually makes sense. It would seem most guys are upset the thing isn't tuneable to a point that it'll support high boost applications, of course that's assuming the turbos are shipped with consistently tuned waste gates, which is likely the issue. As someone who really loves the scientific process, the assumptions being floated as evidence really grind my gears. It's super easy to test spring tensions properly, but because the issue wasn't treated carefully none of the protagonists will ever know. Pointing to a spring and deciding it looks different and therefore is inferior is false. Happy to argue.
    Of course though, if we assume all the actuators are set incorrectly, but actuator travel at a correctly set preload still offers full (or at least effective) waste gate movement then all that's left is a properly set preload. That's also assuming that it opens consistently. Which is almost certain a function of waste gate mechanics and build quality rather than the actuator itself. Thankfully I'm in a perfect position to learn all of these things, tomorrow; with a brand new turbo and waste gate. Any body want to take bets at crack pressure?
    If anything looks even remotely sus after I set preload, ill test the OEM actuator and transfer it, which we all know is just fine for most tunes, almost certainly what I'm planning. I hope. On a stage 3 custom code. Hmmmm... Yeah?
    Happy to take educated advice on this?
    Feb 2007
    Brisvegas
    You're right a lot of crap to sift through. The posts from Marcus Aurelius are the ones to read.
    Adding a heap of preload to make up for a weak spring to achieve the desired crack pressure is not the answer, and I think that's what you need to keep in mind to get the best out of Gav's tune.
    Anyway I don't think the issue will effect the F21 as much only needing 6psi crack pressure (assuming that's what Gav will request) not 10-12 like the F23, but I'm looking forward to seeing your test results for sure.
